MD- 380 Assistance
n9mxq
Belvidere IL
The MD-380 Is a Tier 1 and 2 radio. Cap+ is Tier 3. I doubt it would be able to monitor anything reliably if you put the frequencies in.
Sent from my SM-G950U using Tapatalk
n9mxq
Belvidere IL
Ahh, thought it was. Thanks. Learned something new..
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Since Motorola got shut out of some big wide area network RFP’s that required Tier 3 compliance(Manitoba Hydro and other utility projects), they released Capacity Max, which can be Tier 3 compliant when operated in ‘compatibility mode’
n9mxq
Belvidere IL
Even so, I don't think a 380 could/would track a multi frequency trunking system.. it has room for 1 input and one output freq per zone.
kayn1n32008
Sector 001
In scan mode with all known talkgroups assigned to a RX group call list for both slot 1 and slot 2 on each frequency, it may work if the system is not too busy. Each frequency would need a dummy transmit frequency different than the receive frequency(so not to key on the input by accident and to make the radio see it as a split pair, not simplex).
737mech
Clark County, NV.
Air Canada
You can monitor that system with your md380. Set two channels for each freq with the only difference being the slot number 1 or 2. Then create contacts with those talkgroups. Assign all to a scan list, set each channel to that scan list and same zone. Set color code 8. Should let you monitor.
