MD-380 "English Voice Prompt"
Meestor_X
On the description of this radio, they write "English Voice Prompt" as a feature. I had erroneously thought that this might mean that it has a channel announce feature, but I can't seem to enable it or find anything about it in the manual or CPS.
What exactly do they mean by this "English Voice Prompt" feature?
MD380
n9mxq
Belvidere IL
Although I've seen the "Voice Prompt" listed in several vendors description, I think it's a bad translation. There is no way I've seen to have the radio "speak" it's info.
Meestor_X
Thanks for your reply. I imagine that's what it is. Too bad - that's a feature I'd really like. I saw that on a Kenwood once where as you turned the channel dial it would "speak" the channel number.
Do you know if there's a budget analog radio (in the price range of the TYT) that has that feature?
n9mxq
Belvidere IL
I've never seen voice prompts on ANYTHING I would consider "budget".. Let alone an HT.. But someone may come along and prove me wrong... It's not a feature I use, so it's not in the feature set I shop for.
jonwienke
More Info Coming Soon!
VA
It's in the same category as some vendors calling them "dual band" when what is meant is "dual mode" (digital and analog FM). The menu is available in English and Chinese, but the radio won't read it to you.
Meestor_X
Makes sense. It always amazes me how Chinese manufacturers don't just send their manuals to an english-speaking person; not for translation, but just to proof-read and fix the translation mistakes.
N4GIX
Hot Springs, AR
You've never held the ubiquitous UV-5 and it's many variants then. They will all announce the channel numbers as you scroll up/down the channels, and announce the keys you press when punching in a VFO frequency. :lol:
n9mxq
Belvidere IL
Yep, have one, and as I stated before, it's not a feature I use. Sorry I forgot they had it.. Not like I can remember every feature every radio I own has... I'm too old for that ;-)
Meestor_X
Having channel announce but still needing to look at the radio (find the buttons) to change channels is kinda pointless, IMHO. For me, the whole point of channel announce is when you have the radio on your belt to know what channel you've switched to without looking, which can only be easily done with a rotary channel selector...
So... is there a budget radio out there with this channel announce function like the Baofengs, but an actual channel selector dial on the top?
Meestor_X
On another persons recommendation, I'm going to try out the Retevis RT23 and see what that's like...
Sent from my iPhone using Tapatalk Pro
