MD-380 not decoding
radicalbill
Malta, NY
Hello group
I just got a MD-380 with the MD-380 tools in it.
The green LED comes on when a transmission comes, but the audio does not open
I have it programmed for CC 3, SL 1 on 159.105 for Quakertown, PA
but nothing comes across
I thought that even if the CC was wrong that it would open the squelch and give a garbled transmission
Is this not the case ?
The radio may be defective, I am trying to figure that out.
Any advice ?
Bill
jonwienke
More Info Coming Soon!
VA
No. If slot or color code are wrong, you will get the green light and nothing else. You only get garble audio if your encryption settings are wrong.
gh6406
Dalton,Ga
Hello group
Any advice ?
Bill
Sounds to me like you are trying to monitor a Commercial frequency that probably is using RAS technology.
hill
Middle River, MD
As Troymail said you won't get any audio with just progrmmng in a cc and ts. You need to enter a Talkgroup before the radio will receive anything. If no talkgroup no audio will be received.
radicalbill
Malta, NY
I will program in a TG
I have no TGs in the radio, I did not program it, I got it like this with the freq and the TS and CC, but no TG
I read the manual, which was very lacking.
On the screen, at the top, there is a shield that is made up of 4 block, red and blue, I am guessing this means I am in a digital zone
And in the center top of the display is a little round ball with dots around it.
I think this is a GPS icon, but the radio is not GPS, at least I think it is a GPS icon
It almost looks like an eyeball
Anyone know what these icons are for sure ?
Is there a better manual on-line somewhere that details this ?
Thanks again
Bill
radicalbill
Malta, NY
Can not find how to add TG to MD-380
I am in the software now, version 1.33 of the programming software.
I can add Zones, and Channels, but there is no field to add a talk group
Does anyone know where or how to add the talk group in the software ?
Bill
n9mxq
Belvidere IL
They are added in the contact list first. Then added to the zone later.
Sent from my SM-G950U using Tapatalk
n9mxq
Belvidere IL
Let me clarify, contacts are added to the zone.
radicalbill
Malta, NY
I can't make it work
I don't understand what I am doing wrong.
The firmware version I have is newer than the videos on Youtube and mine does not have the talk groups in the program radio sub menu.
And I have tried to add the talk group as a contact, but it does not show up on the screen.
I see it in the contacts list, but the radio is not getting any transmissions.
The TS and CC are correct, the problem is with it not having the TG active
I see there are two different modified firmwares, from two different hams.
I am thinking I should try loading the other version and see if I have better results.
They should make this software more straight forward, like Zone and then freq under zone and TG under Freq.
The way it is now, it is hard to tell if it is linking to the TG.
I don't think it is.
It may be the radio, but if anyone has one of these radios if you can send me the rdt file with the correct data entered, I would be most appreciative
Bill
n9mxq
Belvidere IL
Did you add the contact to the zone..
n9mxq
Belvidere IL
The different firmware will not change how you program the radio. That part of the system remains the same.
As for sending an RDT, you'd have to find someone in your area that has one. The info in mine from Illinois wouldn't do much good.
n9mxq
Belvidere IL
OK, I missed a step, and I apologize for that..
Step 1: Add all your talkgroups to the contact list
Step 2: Create a channel for each repeater for each talkgroup
Step 3: Add the channel to the Zone (assuming you've already made your zones)
