Tytera MD-380 programming
DeRanKeR
Dry Ridge, Kentucky
So I recently was given an MD-380 as a birthday gift. I've taken steps to program a local amateur repeater in and every time I try to write to the radio it reads the error the frequency range is wrong. I have it set to 136-174 MHz and the frequency I am joining is 147.375 and the repeater is in analog mode. The radio is also set to analog.
BruceMurray
So I recently was given an MD-380 as a birthday gift. I've taken steps to program a local amateur repeater in and every time I try to write to the radio it reads the error of wrong frequency. I have it set to 136-174 MHz and the frequency set is 147.375. Any ideas on what to do here? Unfortunately videos are limited and fail to answer this. Thank you!
Are you sure you have the vhf model and not a UHF (only) model?
w2xq
Burlington County, NJ
Unless I am mistaken, the.MD-380 is UHF only. The screenshot says you have the 380, so it won't take a VHF frequency. FWIW the MD-UV380 is dual band.
ergbert
FN22
My guess is that you have a UHF model. What does the sticker beneath the battery say?
Here’s mine:
BruceMurray
The MD380 comes in either VHF or UHF.
Single band vhf or UHF. Look at the label on the radio under the battery for which band you have. The software works on both models, so it let's you select UHF or vhf in the menu. But the hardware cannot do both bands in one radio.
