Tytera MD380 Weirdness
Kennrth
Bay Shore Long Island NY
I have 2 MD380's The new one has firmware D014.007 CP ver 1.30. It works fine. It is a UHF version, THe Code Plug Loads up and works fine on both radios. When I read the code plug on the new radio it reads very fast. It reads all the data correctly except it thinks in a 2 meter radio. It shows this in Basic information panel. Shows Freq 136-174. It is wrong. All my repeaters and hot spot frequencies are UHF. The label on the back of the radio under the battery says 400-480Mhz. Weird
My Older Md380 doesn't do that. It also had MD380 Tools installed.
When I use third party software. DMR Code Plug Editor V1.1.2 1by G6AMU it doesn't do that.
If you have any ideas. Email me kconno6121@gmail.com
Ubbe
Stockholm, Sweden
Maybe TYT have done some simplification and have more common code between the single band radio and the dual band one and the databit that tells what band it is have moved and can't be handled by an old CPS. Have you search for any newer codeplug programmer version from TYT?
/Ubbe
