MD782 failing
phadobas
This radio keeps rebooting after about every 30 seconds (it varies but it's alway less than a minute). It's out of warranty and I replaced it with a spare, so I can freely "play around" with it. I'm trying to revive it. So I completely took it apart. On the circuit board there appeared to be some slight sign of rust here and there and I brushed those off. They came off easily. I fully cleaned up all parts and put it back together but the problem continues: short uptime and then reboot.
So I attempted a firmware update but it fails, seemigly on the last step. It erases and re-writes many parts of the stored data or software, but then it always fails with an error message after about 6-8 minutes:
timeout error [cps_data]!
This is how far I got and can't get past this point. I can't even turn it on normally any more, looks like it's corrupted due to failed firmware update attempts.
Anybody has any ideas?
radioopperator
Have you updated the FIRMWARE with the latest and are you using the PROPER CABLE? the one with the switch on it?
phadobas
The version I have is V9.02.03.005. And yes, the cable is the right one (used on other radios), with the switch on it.
