MD785 programming problem.....
Sputnik1
Kettering - Northants - UK
Happy New Doo Dahs to one and all !!!!!
pleasantries done with now to business........
I have a fully functioning MD785 but it cannot be programmed.
The CPS does not ' see ' the USB connection from the radio hence it cant be prog'd
this is the same if tried from the front mic socket and the rear multi connector.
even when putting rig into flash mode the USB still not seen by upgrade tool
prog lead, laptop and CPS all ok and verified on another rig CPS is 8.05
any ideas how to get round this ??
not adverse to chip changing if I know which one to swap
many thanks in advance
Sputnik 2020
Pittsboro IN
Are you saying your PC reads and writes to one radio and not another?
When you say the 'the USB still not seen by upgrade tool' sounds like a PC/USB problem.
TheBoz
Vernon Co, Missouri
Sputnik 2020
I’m not sure if you’ve tried doing it this way or not, but the only way I can get my Hytera radios to program is to first open the software, then hook the cable to the radio, then turn the radio on and then plug the program cable to the computer, I hope this helps, but it’s the only way I can get my to find the USB, and this is how the dealer I bought them from informed me to do it. Good luck!!
Sputnik1
Hello SN
my pc leads and cps all work fine on many radios.
its just this one particular MD that cant be read or written to as the USB connection cannot be seen by the PC
this is what I get with target radio powered up and connected
78847
Same PC, same lead + same CPS works fine on all other radios.
seems i may have a hardware issue with the rig.
If I cant re-prog it I would like to wipe it but dont know how to achieve this without a working PC connection.
I have even tried connecting a keypad mic and going through the programming settings
but even though the mic works normally the keypad element doesnt.
any help gratefully appreciated.
many thanks
thanks for the tip - just tried it still no joy :-(
I must admit I have never heard of that sequence before but it was worth a shot.
Before I take the big leap of faith and send it for FPR I would like to wipe out the channel list at the very least.........
cheers for now
regds
Sputnik
Pittsboro IN
I plug the cable into the USB, start CPS and then plug into the radio. The programming cable should be recognized regardless if there is air or a radio on the end.
I have seen CPS program a few radios and then not recognize the USB as you show in your screen print. I put the cable into a different USB port and CPS is happy again. I had a Trbo CPS wipe out a USB port of a PC where nothing would be recognized, it took some effort to re-enable it.
