MDC ID Alias Question
jolt1
topika, KS
For regular MDC ID someone had their HT1250 radio programmed that the MDC id had an alias name attached to it so it said text instead of just numbers when decoding.
how is this achieved in the cps?
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
CPS ---> Call ---> MDC Call
Create an alias for each ID number that you want.
Make sure the System numbers match and the ID number and type is correct
jolt1
topika, KS
Cool - Works great.
also i see there is a revert feature... i noticed this switched my radio when putting out a select radio call... it transmitted only on revert Chanel if selected...
is there a way to send a select call and switch a radio onto another Chanel.
or to switch my radio to another channel when i receive a call from them?
Also how can i make it play a tone? the name tone tag did not do anything...
