MDC Receive/Decode in Hexadecimal Format?
fdnybuff18
NY
Has anyone been successful with receiving MDC Signalling in Hexadecimal format? I have the "Call ID Display Format" set to Hexadecimal, but still comes up in Decimal Format. This setting is under Pager Configuration Settings>Display Setting Format>Call ID Display Format. I am almost certain that about two firmware in past, the MDC came up as a hexadecimal.
Is there another setting that I am missing?
fdnybuff18
NY
Wow, dropped the ball on the original post.... This would be on a G5!
Citywide173
Attleboro, MA
I have been playing with the PPS settings for a while now and have the same problem. Hopefully it's a simple setting and someone will have the answer
Loopy1
Central Virginia
The pager used to have a menu choice to select hex or decimal but that disappeared several firmware versions ago. The PPS selection never has worked properly for me and the pager always displays decimal no matter which box you check. I wish they'd fix it since our unit numbers only display properly in hex.
