MDC Signalling via Motobridge and MTR3000
KI7WB
I am running a VHF analog repeater system that uses an MTR3000 base radio connected to a Digitac and pair of 4-port Motobridges as the repeater controller. I'm having difficulty getting Pre-MDC signalling to successfully propagate through the system. There are two remote receiver sites also voted via the Digitac. User radios are the XPR6550 portable and CDM1250 mobile radio. Can anyone suggest the correct Pretime or other provisioning timers necessary to allow Pre-MDC signalling to work in this narrowband analog radio system?
tbearsch
Bloomington IN
Filtering
If you are using idle tones on the receivers, you may have the notch filters on which may strip the MDC. is the issue with the timing, or just lack of mdc?
KI7WB
The notches are not in. MDC signaling timing tests are showing that the actual pretime from an XPR6550 does not agree with provisioned pretime. Actual is about 18ms until provisioned reaches 220ms or so, then the values track linearly. Provisioned 250ms is 68ms actual, 400ms provisioned is 224ms actual. The CDM1250 actual pretime is about 25ms longer than provisioned, and linear.
