Measuring Communications System Performance: What's the Norm
ahawkins
Hi there. I am trying to get an idea on how data performance is measured over a trunked digital radio system. I came across this information on some technical website. It is listed below, talking about a given message model, and was wondering if this was a valid method of testing a digital/data system. The table is also listed in an attached file as well. I was also curious if there were any other methods of testing data system performance on a trunked system, that are used by the major vendors (ie Motorola, MA/COM, LTR, etc). I am trying to get an idea of how this is done in the industry, to include in a paper that I am putting together on digital radio systems. Thanks.
Using raw data bit rate to compare data systems can be very misleading. The actual system performance depends on a variety of factors including the protocol efficiency, signaling conditions, system loading, and the particular application being used. The true measurement of a public safety data system is the number of users the system can support with specific applications. This information is typically provided in a message model similar to the one shown below. By requiring each vendor to define the number of users a channel can support with a specified message model, a customer can make a true comparison of the data system’s performance.
Example Message Model for Law Enforcement.
Message Inbound (to Base) Outbound (to Mobile)
Bytes msg/usr/hr Bytes msg/usr/hr
Login 253 1 185 1
LP Inquiry 193 5 256 5
Email with
Confirmation 386 3 212 3
DL by Number 186 2 225 2
DL by Name 162 2 232 2
Changing Status 148 6 52 6
Changing Status
Broadcast 10 chan 0 0 148 60
CAD Query 196 5 226 5
Log out 172 1 74 1
CAD-to-car 50 1 200 1
Field Report 7000 0.5 3000 0.5
Mug shot 250 0.5 7000 0.5
AVL 40 12 75 12
D
DaveNF2G
Guest
You're taking a big risk trying to do serious research by asking questions on a web message board. How are you going to validate the sources? Anybody could come on here and post b.s. - how would you know?
