MECA Digital: reception issues and solutions
Viper43
Any place around Central Indiana to get one or just have to order from the Internet?
The only place I know of I can't remember the name off hand and not sure they would have one either. You could wait another week and try the hamfest in Greenfield, you might find one pretty cheap.
V
jwoody062
Indianapolis,Indiana
MECA Digital: reception issues and solutions PSR-600
This is just an update for anyone still having trouble with reception issues,I have tinkered with the radio so many times i finally found the best setup,I Have only the control ch programmed into the freq. and no to the fm setting and muti site off,and im only using the supplied antenna, the radio works just as good as it did on the other system.Thanks to all the members with their suggestions.
rdale
Lansing, MI
Multi-site should never be on for a simulcast system unless you are driving into an area with a different CC. You never should program anything other than the control channels.
What kind of trouble does that put them in? Will they need to stop transmitting on the 6th?
Yes and No they can use the old tower sites but all the new ones would need to be shut down but I really dont think MECA would do that they would just keep operating and pay a fine if they got one or got cought heck they where using new freqs and towers with no lic before. OR they could go back to the Analog system till the lic issues where done
Pittsboro IN
STAs are only good for 6 months unless they have been coordinated by the freq coordinator, I guess the FCC noted the words "pending frequency coordination" and decided to pull the plug.
The rejection letter will be on the website under the Admin tab - Letters heading, they usually show up after the midnight to 2am downtime for daily maintenance.
I've had a few of those letters, they're usually minor items, such as a frequency being available for itinerant use only, not mobile of fixed base. I can get licensed on the rejected freq just by changing the station class to match, it's still the same freq and modulation scheme.
loumaag
Silent Key - Aug 2014
Katy, TX
Let's stay on topic
Fellas,
There has been quite a number of posts about MECA and the FCC; other than possible farming that data for site locations (hardly needed), the trials and tribulations of MECA and the FCC have nothing to do with the topic of this thread: MECA Digital: reception issues and solutions. Posting this information may be of interest to some; however, it is not to the point of this thread. For those of you interested in the minutiae of relationship of MECA and the FCC, start a new topic on it, thanks.
pliquett
Fishers IN
jwoody062 have do you set the fm to no? I have a psr600 and I can't find where to set that anywhere. Thanks.
rdale
Lansing, MI
It doesn't matter - those settings have no impact on the scanner when trunking a P25 system like MECA.
jwoody062
I live in the downtown area,I tried programming it several ways and when i programmed only the control channel and set the narrow fm to No im getting the best reception and works just as good as the old system,something made a difference.
jwoody062
What happen at meca,as of last night before i went to bed i was getting 100% reception,I wake up at 3am I cant received anything no signal nothing?I have both the PSR-500 & 600 the signal is gone on both radios?
This is the first time they have rotated there CC every one should check there radios make sure you have the 4 CC they use or all the freqs programed in to make sure you dont loose the system.
The 4 CC MECA SYS 1 uses these are from MECA not my self
858.1875
856.5125
856.1625
857.6625
They have rotated back now
