Viper does RS still sell the antenna the only one i know of is an all band ant that doesnt work,can u be a lil more specfic on how ya rigged it up?Thanks
It's the http://www.radioshack.com/product/index.jsp?productId=2102525 and in most stores I use a "through the roof" BNC type mount which is actually a panel mount BNC then run LMR 400 (thin type)
to the scanner. Simple yet it works. If you don't want a permant setup then use an old mag mount CB base with a PL-259 to BNC adaptor and the LMR 400 cable in place of the CB cable unless it has really good cable already.
V
They make a car window lip mount with a BNC and fairly good cable, or there are several commercial magnet mounts with a BNC base which has a good cable for two-way radios.
They even make one with suction cups for window mounts.
http://www.scannerworld.com/content/product/model/SCAN9BNC
Or you could use a window mount antenna, some like, some hate, and some don't work depending on how much metal is in your window glass.
Godd selection here
http://www.scannerworld.com/content/product/category/Mobile%20Scanner%20Antennas
What you suggest is overkill, costly, and the results would be hard to measure with out special equipment. we are talking about 5 to 10 feet of cable here. There is barely any loss. Most cable loss is measured per 100 feet.Why spend $500 on a scanner then skimp on the antenna and cable, heck, I wouldn't skimp on a $5 scanner antenna for that matter as the antenna and cable are the most important part of gettng the best recepton possble. Add to it the fact the RS 800Mhz duck s a proven antenna, and for less than $50 you can have an excellent setup, not "fairly good" cable that wll give fair results at best....
Reminds me of a certan fire department that bought 45 new radios for $1200 each then bought surplus antennas in a lot of 50 for $100 and wondered why all their new radios wouldn't transmit or receive. Even after being told it was the antennas they failed to fx the issue until they burned up 4 of them..... Granted a scanner won't fail the same way but performance does on reception.
V
Getting a 4-6 inch piece of metal the size of toothpick on the roof in a mag mount would produce amazing results. Better than a RS duck. Get it up ten more feet and reception might almost double. A metal antenna beats a RS duck every time.
lol, you contradict yourself as usual, first saying it's overkill then saying it won't work, well I have tried over 50 antennas and stll the best performance is the setup I suggest, whch BTW orgnally came from someone who builds and repairs 800Mhz trunked systems. And the LMR 400 doesn't just cut down on loss, it also blocks out interference , whch, wth todays cars/trucks is much more mportant than it was before. The RS 800Mhz has proven it'self time and time again, where "wire" antennas have failed.
V
The National Institute of Standards and Technology (NIST) ran some tests (back when they were still the NBS) on Public Safety high band and amateur 2-meter antennas. They found that a "rubber duck" has -5db gain compared to a quarter wave antenna held at shoulder height. In terms of effective radiated power (ERP), a 5w HT with rubber duck antenna, held at shoulder height would actually radiate 1.5 watts. Placing the HT on your belt attenuates the signal another 20db, reducing ERP to only 15 milliwatts! UHF results weren’t found to be much better.
www.scc-ares-races.org/emergency_operations_and_ht.htm
If you want to listen to MECA, get an 800 MHz yagi. Get the shortest run of coax possible. Point it to the direction of the site you want to hear.
If you want to listen to UHF/VHF freq's than buy another scanner, and put a VHF/UHF discone on it.
Come up with a new inventive use for the rubber duck
It takes at least a 6db change in gain to notice a diffrence. RG-8 is in the area of 6 to 8 db attenuation over 100 ft. LMR-400 is 4 to 6 db attenuation.
RG-8 runs anywhere from 30 to 50 cents per the foot. LMR-400 runs 70 to $1.30 per the foot.
If you have a short run, like most listeners do, to the attic, or a mast outside the bedroom window, is double the cost worth almost no noticible increase in reception?
After reading many posts extolling the virtues of the RS 800 MHz rubber duck, I bought one. I was not impressed.And there are better ducks out there than the RS 800...
Old outdated info form 2002 and Races is worthless for any real info
It is amazing that Marion County didn't join SAFE-T. Then again, consider who was in office at the time the decision was made to go with the P25 system...just another bone-headed decision by the former Peterson admistration.
