GTO_04
Yes, I've updated to 3.01, set to P25, and I have four CC programmed. I've also experimented with the AGC and P25 Adjust Level settings. Still, very poor reception...garbled and broken up most of the time, but with strong signal strength. Any recommended settings? Thanks.
I think from where you are located, the 396 sensitivity is too low to pick up MECA. My 396 cannot pick it up either. My PSR-500 can pick up MECA from Noblesville. I recently got a Pro-197 and and with an external antenna it can pick up MECA just like I was located in Indy.
You may want to try an external antenna with your 396. For the best decoding on the 396, set the P25 adjust to "Manual" and set it to 8. Even with the new firmware the auto decode is not all that great, especially with weaker signals. Also it seems that the decoding is better in scan mode compared to search mode.
GTO_04
