I am using Win500 to program my scanner. I am going through and double checking everything. For the MECA system 1 should there be anything listed under Trunking Table? I have data there for some reason. I used the web import in Win500 thats grabs the data from the RR database. See the screen shot (TrunkTabel.jpg). There is an option for selecting standard band plans. I was curious if the P25 800mhz Standard should be selected? See screen shot (TrunkTableSel.jpg) to see the list of choices. I don't know if any data should be here or not but I am sure that if it were not correct it would cause a lot of issues. Thanks for the help!!!
It looks right, but I don't know. I recommend joining the GRE 500 Yahoo group.
This is what my Uniden BCD395 has for P25 systems
851.006250 6.250
762.006250 6.250
Also, try changing locations in your house/Apt first before you do anything else.
It might surprise you. And there are one or two other users on here that have GRE's
This guy, tbhausen has an online feed of a GRE 600.
Also try the attenuator in case it is getting overloaded.
