Medicine Hat monitoring
Bussard
Looking for a scanner to get latest MHPS and Sheriffs in Medicine Hat.. The above scanner is not made anymore and would like to find one that would work.. Beginner here
Looking for info on what I need for a scanner and a detailed review on the procedure needed to receive AFRRCS, new to this. Thanks
robertmac
If as most police agencies are, going encrypted you are SOL!
harryshute
Edmonton, Alberta, CANADA
This could be another 5 years..
So are Medicine Hat Police still on 800 Mhz or have they made the move to AFRRCS? Didn't catch the model of scanner you are replacing. If they've made the move wouldn't be surprised if they went to encryption and no scanner will solve that.
cpnstubing
Medicine Hat, Alberta
MHCP
MHCP is still on 800Mhz - TAC is encrypted but primary and secondary channels are in the clear (P25)......highly doubt they'll be moving to AFRRCS.......system they've got is fairly new....but only their admin knows for sure.
harryshute
So for Buzzard a scanner that will receive 800 MHz P25 should do it for him.
cpnstubing
I would say so.....I’ve had AFRRCS programmed into my 996T sine they started transmitting and haven’t heard anything whatsoever.......only thing first responder variety appears to be MHCP and MHFD....both on 800mhz
Bussard
So what’s the scanner I will need?, they show 866, 867 frequency
harryshute
Well we know Captains Uniden 996T works there. So that would include the Uniden BCD396T and 396XT and the 996XT which are older models that might be purchased cheaper than the newer models like the BCD 436 and 536 models. Some other Medicine Hat members may have some Whistler models to suggest.
mark2117
Alberta
The last I read from local news is that they were taking delivery of the new equipment for the new system the past January/February. I tapered my listen habits in January and haven't checked to see if they did actually switch or not.
The GRE scanner I use just shoots errors at me every time I turn it on anyway. If I fix it some day, I'll come back with an update! haha
