Yes, be very concerned about noise, mostly on HF. If you plan on any wire antennas keep them at a right angle to the power lines and as far away as possible. You might also try a portable HF radio at the property to see if its a total wipe out, which could help decide if its a bad place to live.
There are also potential health risks like leukemia from living too close to super high power lines like over 500kV and it all depends on the exposure levels and duration your exposed. Its one thing to be exposed to large EMF fields at work for brief periods but you spend a lot more time at home, so I would recommend getting some data on what EMF levels might be bathing the house your looking at.
You will find lots of info on the Internet about this with some saying there is no risk at all at any voltage or distance, probably from studies funded by the power companies. The World Health Organization is definitely attributing higher risk of some cancers and other problems from living in close proximity to high power lines based on many studies in many different countries.
Ok, now I'm worried, find another place to live and one that is better for your hobby. Don't buy it!
I am looking to purchase some property for my new home and would like to build an antenna farm on it (shortwave up to UHF). The property I am looking at purchasing sits up pretty high in the county but there is a megavolt? transmission (unsure of actual voltage) line running on one side of the property, roughly 300' from my antennae location. I hope to find out more specifics this week, as far as actual voltage this line carries. Should I be concerned about this for an antennae farm?
