Memphis digital frequencies, frequencies, frequencies
Vol4Ever
Apologies to all for starting a new thread, but I'm hoping to get a concise list going here without having to read through 14+ pages of notes in Ron's original APCO-25 thread. After reading that thread in its entirety, I have come up with the following list of potential frequencies in use with the "new" digital system. All of these are mentioned at least once above:
858.9375
859.4625
860.2375
860.7125
860.9625
866.3000
867.9875
868.5375
868.9375
Can anyone shed any insight into this list (RAY??). As a new scanner user, I'm getting wayyy overwhelmed trying to keep up!!
Russ
Gatorman
Memphis, TN
Russ, I have not attempted to compile freqs. I have setting the control channel only. This should do the trick. I have been using the control channels indicated in the RR database which seems to be accurate.
I understand, that programming only the control channels allows a much faster search rather than have the radio search through all the programmed channels. I'm talking about the 396T at this point.
I posted the control channels that I am using in the last couple of days on the APCO-25 thread. Let me know if you can't find them.
I have pretty much figured out the basics of this radio. I have not tried programming software yet though.
tspainiv
Shelby Co DB Admin
Collierville, TN
The two control frequencies I have with the system ID of C11 are 860.96250 and 859.46250. Those are the only I have found that are associated with the new system. Unless there is traffic on the other control channels.
