Mercer County Trunked System
edisonfire
Hi all, I'm using the Unication G5 when driving through various areas of NJ and nearby. Has anyone found the Mercer County trunked system falling short? I was in downtown Princeton, not far from the old Princeton Boro police station and my G5 kept giving me out of range notifications. I switched to Somerset 700Mhz as I was headed home and the Somerset was blasting even in downtown Princeton. Anybody from Mercer LE or Fire notice shortcomings and/or all out dead areas? Bucks County PA also booms into Mercer County.
policefreak
Berlin, NJ
So it looks like the nearest transmitter to Princeton is back in Lawrenceville around Rt 1 & 295. Your G5 has a disadvantage in that it's picking up the UHF through an internal antenna which has historically proven weak. Still, even if your G5 were in cupholder of your vehicle while driving I would expect you to get something. In any case I have seen some weakness on that system though not to your extent. My SDS100 scanner which does not suffer from simulcast distortion and can be a decent receiver on T-band UHF, has lots of trouble picking up Mercer County from Bensalem, Pa and Eastampton, NJ both of which are less than 15 miles away.
edisonfire
Thanks for the reply. I was tossing it out to see if any first responders who use the Mercer system report or have noticed deficiencies in radio use.
