Howdy,
I am wondering if anyone has identified an efficient way to merge V-Scanner folders using EZ Scan (or any other software). I use different V-Scanner folders for different geographic areas. On my main, "home", V-Scanner folder, I have over a dozen scan lists for common channels like aircraft, interop, DPS, FRS/GMRS, state and federal agencies, etc.
I would like to be able to include the "common" scan lists in with each geographic V-Scanner Folder without having to re-import all of the common frequencies from Excel (and change the settings that never import properly, such as modulation). Basically I want to merge two folders together.
I know how to copy V-Scanner folders. And I now use my "home", comprehensive, V-Scanner folder as a template when I start a new folder. However, I constantly add things to the "common" template, and it would be nice to quickly update it rather than import hundreds of entries into over 15 different V-Scanner setups.
I hope someone has some tips. Otherwise, I guess I have a lot of grunt work to look forward to. I'm using the WS1080.
Much thanks to anyone who speeds this up for me!
