Message skip
Granny54
Missouri
I'm a newbie and I'm wondering if there is something wrong with my scanner. Every time something comes across the scanner part of the transmission seems to drop/skip. It's really annoying to miss pieces of the conversation! Any ideas what is going on?
Thanks!
CT
Check Weather Alert Priority
No PRI showing on anything
"Weather Alert Priority Turning the weather alert priority feature on allows the scanner to check the weather channels every 5 seconds"
Otherwise, it's possible you are too far away from the transmitter?
RBMTS
Check to make sure that "Close Call" or CC is not turned on. That would also be a symptom on a 996P2.
