Hello
Need some help on this.
I have OCF antenna and mounted to a flag mast and just bought a new Yaesu ft 991a . It's receiving well but not getting out . Running Rg8x coax about 70 ft and didn't want to cut it so I coiled the rest 30ft up and hung it up outside my window. I know the balun is to close to flag pole. So I made a plastic PVC pipe as a stand off. How far away shud the antenna and balun be from the flag pole I made it 3 1/2 ft .one leg of antenna is going thru some tree branches. Will that affect antenna performance. The antenna is in a inverted vee.i had inverted vee before and only up 17 ft and legs off the ground 3 ft and worked wonderful also between 2 houses. So what else can i do to get this OCF to work .it's a radio waves OCF.
