Metal Roof base Antenna
JayMojave
Mojave Ca
Prcguy had bought two SPT500 antennas and was going to show all of us how they need to be assembled / tuned. Hope he posts it soon.
Jay in the Great Mojave Desert
FPR1981
Vector 4000 all the way. I've compared directly against the Penetrator. No comparison, IMHO.
The Vector is an absolute powerhouse, and it talks skip effortlessly. I cannot suggest it enough.
prcguy
I got one Penetrator assembled and tuned up no problem at about 5ft off the ground. They redesigned the matching network at the base, it used to be thick aluminum wire and now its a stamped sheet metal thing and shaped different. The original 1970s and the last version I bought about 10yrs ago had double wall tubing for the bottom section and now it looks like single wall. They have found ways to save a few more pennies but the basic antenna is still the same and will work the same as the 1970s version except for more sway in the wind.
The sheet metal matching thing was a bit distorted in the shipping box and I found bending it around will change the match some and you can do some final fine tuning by bending it closer or further away from the antenna. I still think the Hy-Gain Penetrator the best thing going in CB antennas despite what the toothless inbreds at MFJ have done to it since MFJ now owns Hy-Gain.
The dimensions in the instructions are for 10m amateur use but you put the ground radials together as they specify at 105" then start with the vertical element at about 22' 6" and adjust for the best match on CB. Mine is around 22' 9" when centered around CB channel 20. Raising it way up in the air will probably change that slightly.
prcguy
Uhhh, no. I don't think there needs to be a video, the instructions are ok and there is not much to go wrong. Once its together you check the match and change the length of just the the vertical element until it works where you want it.
Prcguy did you make a video on you setting up and tuning them by chance?
Papseylathers
Ok thanks do you have anymore pictures? Do you currently have this mounted?
