Ware37075
No longer receiving Nashville Police & Fire dispatch. I am using a Uniden BCD436HP. Anyone have any insight on whats going on?
I'm not familiar with the 436, but I too was not receiving Metro on my GRE PSR 500 and 800 until I loaded the control channel that someone posted above, 857.0375, and then I began receiving Metro on both radios. (Monitoring from Murfreesboro.)Well i loaded all cc into my bcd 436 hp, plus all secondary frequencies . Im just not having any luck receiving the metro nashville p25 system!
Any suggestions would be appreciated.
I did receive some of the fire departments transmissions for about ten minutes and then they went dead !
No trouble with receiving Mt.Juliet!
The Radio Shack 800 MHz antenna. Also, in reviewing the previous posts in this thread, it seems that the problem may be with the Uniden scanner. For example, the poster that began this thread, (see above), was using a 436 and then later on another commented that he couldn't receive Metro on his Uniden but could on his Pro106, which I think was made by GRE before they went out of business. Just as a suggestion, maybe you could check with those two posters to see if they ever solved the problem. Also, if it is the Uniden scanner, maybe a post in the Uniden forum would help.I loaded same cc frequency along with others listed..still no luck !
What antenna are you using ?
