A good combo for the R20
Wow - has it been 7 years already?
The MFJ 1020C makes a good combination for the Icom R20. I have also tested it with my Kenwood TH-F6 handheld, along with other communications receivers like an Icom R71a, Yeasu FT-840 etc.
Like mentioned before, the same rules about antennas apply: inside the depths of the house, not so good. At the windowsill even better. Better still is outside!
While the comm receivers needed no attenuation, I run them with their own internal preamps off, and the MFJ at max gain. With the Icom R20 or the Kenwood F6, both are running at max gain with NO internal attenuation. Tuning with the handhelds can be tiresome, especially if you are tuning at .01 khz step rate for fine tuning. Still, a lot of fun.
However, on bands lower than about 10 mhz, the R20 and F6 benefit from rolling the gain of the MFJ back just a *smidge*. So the MFJ on it's own is not an overload box.
If I had to compare the MFJ 1020C to something else, it seems to perform about as well as a GOOD mobile setup, or at least as well as a GOOD installation of Hustler mobile whips (for you amateurs out there...)
I run with my own small whip instead of the supplied one. I used an SO-239 to BNC adapter, and a Diamond RH-789 telescopic whip with an angle knuckle. I didn't want to turn this into a different antenna, but stick with the small amplified whip concept. With longer antennas, you might as well build something else.
On occasion I'll run it outside instead of from the windowsill, and that means the loss of convenient band retuning. However, If I'm sitting on a band for the most part, I can pre-tune the unit, disconnect it, and run it outside with my 25-foot long coax feedline. Either that, or crank up the audio and tweak the MFJ that way.
Note that like the Apex 700DTA active antenna, tuning is touchy, and on the MFJ, the bandspread is a general guide - you could be 2 mhz or more away on the dial. To make it easier with the R20 or F6, run the MFJ at max gain, tune for peak, and then back the gain down just a hair.
Running it outdoors on the deck places the unit farther away from noisemakers. And, since I'm not running long antenna elements or radials with it, the small footprint allows me to find spots that are in noise-nulls much easier. While it doesn't seem to rely a lot on the common mode, I do run with an RF choke like an MFJ-919 or airwound choke like the RadioWavz ISO-X just prior to the rigs for good measure. However I had no problem running straight from the MFJ to either the R20 or F6 directly either with just a 1 foot jumper.
Does it replace a good outdoor antenna? No. But instead of heavily attenuating the R20 or F6 with my main antennas, all it took was backing the gain down a *tiny* bit with the MFJ optimizing it for the handheld radios.
So in the end, surprisingly good reception, but it won't open a dead band, or compete with a 120-foot flat-top up at 80 feet. But it does work, and isn't as bad as most people assume as long as they aren't doing something dumb like trying to make it work in the bathtub or on top of wall-wart. (I run mine from an internal 9v battery btw....)
