These three programsI just purchased a MFJ-8322 scanner and found the USB cable I need, but I don't know what software is compatible. Having trouble finding this scanner listed since it is still relatively new. Any help?
Thanks.
Should work, the 8322 is clone compatible with the PSR-300/400 (CPU 1.4 and above) and the PRO-163/164.More specifically (the first 2 come from the 8322 wiki...);
*and maybe Win97 from Starrsoft, at the URL given...(has anyone tried it yet with this scanner)?
73 Mike
You should not need to press any keys on the scanner to do the transfer. The program should send the necessary commands needed to get the scanner to transfer it's configuration to the computer, or to accept what the computer is sending to it. The scanner will display the Clone mode message any time the cable is plugged in, that's normal.Well, trying to upload to scanner but having problems.
I am using the trial software ARC300 and have successfully connected to radioreference with no problem. When I try and upload it acts like it worked (the software), but no data is changed on the scanner, the entire time the scanner just shows "CLONE MODE Press UP to send. Remove cable to exit"
When I did try and send from scanner it always says "CLONE MODE No Response ! Remove cable"
I did a search for "No response" and got no hits from the forum which I thought strange. I'm sure this has been addressed, just dont know where.
Thanks again.
You can try installing the latest FTDI drivers for the cable and see if that helps.No luck. Rebooting has made no difference.
I do see a led light flicker (on the cable) when trying to send or receive, so i believe the drivers and cable are good, at least up til it gets to the scanner. The cable is fully seated...I am out of ideas.
Yours is a PSR-300/400. PSR-500/600 shouldn't be listed in software menu.I did disconnect cable, install new drivers and reconnect but it seems to have made no difference.
Should I be selecting something other than PSR-500/PSR-600 for the scanner model? I am using the MFJ 8322.
Thanks,
Sounds like you may have the wrong software. The MFJ-8322 is basically a PSR-300 with the MFJ name on it. The software you would want to use would be ARC300, WIN97, or PSREdit300. If sounds like you might have Pro96Com or PSREdit500, which will not work with this scanner.I did disconnect cable, install new drivers and reconnect but it seems to have made no difference.
Thanks,
