Finally had enuf of the noise floor blanking things out at night so I'm setting up a MFJ - 1026.
I'm going through the operation setup and on page 12 step 8 (advance the MAIN ANTENNA GAIN until you just see the s meter change).. Will it change up? Change Down? Or can it go either direction?
On a side note I'm running a IC 7300 and normally I'm running NB, NR, P.AMP1 I turned the nb and nr off to the noice cancel. Is that the correct thing to do?
Anyone that can give me info is appreciated!
