Mhp Low Band..
btritch
I am in Northeast Arkansas and I can hear The Missouri Hwy Patrol on Lowband 42.240 or something close to that..I have the exact frequency but I cant' place it off the top of my head, Anywho, I can hear the dispatch center just fine..But I can't hear the Troopers Reply To Dispatch, I can hear dispatch but not the field officers, Is there a reason for this? Something I'm doing wrong? Does anyone know how to fix this where I can hear both? If it helps, I have a scantenna about 45 feet in the air..I don't know what the problem is..
mancow
N.E. Kansas
Similarly to CHP the MHP uses offset frequencies. They transmit on a different frequency than they receive. Check the database for the details. Also, it's a non repeated system. So, to hear a mobile you would have to hear them directly from their vehicle and that's unlikely unless conditions are correct.
Basically, their system follows the same rules of skip and propagation as 6 meter ham radio. If you google that you will see why they call it the magic band.
btritch
Googled, Read, Understood, Brought Up To Date, Had No Idea, Thanks!
KM5LZ
O'Fallon, MO
Mshp
Have you been to Couch's lately?
I lived in Gosnell for 13 years and never could hear anything from Poplar Bluff. Then I moved to Poplar Bluff and only heard dispatch most of the time. From my house I could see there tower about 2 miles away. I had the same problem with the ASP I only heard them on the sheriff net.
Now I live in the St. Louis area same thing here. Good Luck
