emtbls1987
- Joined
- Dec 2, 2007
- Messages
- 205
Anyone know what frequency MHP uses in Polson and south area. I’ve had 154.785 in my radio but haven’t heard anything.
You hear MHP from Polson area ?Is that the only site you get from your location I would try listening to every active site in your area. I pick them up all the way over here in Philipsburg at times they bounce off Conoco Mountain for me. But I know they do all operations on the P25 system in that area.
What type scanner do you have? Is it P25 compatible? What type software are you using to program?I listen to big arm site and nothing
If it is P25 compatible, you should be able to add some of the MPSCS sites, check for control channel signal, keep only those you receive well.
The RR database has the talkgroups for MHP in Kalispell.
73, Rex
I'm just curious why if live in those areas your not listening to the Montana P25 system.
You can always use “analyze “ if you get a good control channel (cc), then use the “discovery” feature to get talkgroups.
The 996XT doesn’t have the “analyze or discovery “ feature, the newer 436/536 HP and the SDS100/200 have this, sorry.
Set the 996 up for “ID search”, it’s like a wildcard, any Talkgroup will show up on the sites your monitoring. If it is on “ID scan” then only talkgroups programmed will show, No wildcard talkgroups.
Keep monitoring, something is bound to show up on the sites.
Sentinel is for the newer Home Patrol I & II, 436/536, and the SDS series.
73, Rex
