Mic Gain setting on TK-2170 & TK-2160
Marco192
Hi guys,
is there a way to change values for mic gain settings on TK-2170 and/or TK-2160. I have looked in test mode menu, but found no options for microphone settings. I would like to change values for "normal" and "high" sensitivity option in the programming software for use in noisy environments.
Thanks!
kd4efm
EL98 Florida
Should be under options, not test mode.
Sent from my SM-G935P using Tapatalk
Marco192
Under options you can just select normal & high settings, but I would actually need a "low" setting
