Mic problems
emtbls1987
hello Eveyone again,
I am having problems with my radio. i go to transmit to test the radio and sometimes it goes blank except the xmit,and RX are lit then it comes back on. is this more then likely a Mic Problem of is it worse.
Emtbls1987/fire
FFPM571
Nashvillle
You cant power a spectra that draws 25+ amps on tx with a CB power supply that puts out maybe 10 amps it will recieve because the reciever draws maybe 3 amps
emtbls1987
Spectra Mic Problem
Hello All
I have checked the Amps on the Box. it is 13.8 V that is coming out of it.
FFPM571
Nashvillle
Its not the volts ... Its the amps. it needs at least 30 amps to fully transmit with a highpower spectra. amps are different than volts
jim202
New Orleans region
You need to measure the voltage while your trying to transmit. What everyone is trying to tell you is
that your probably pulling more current (AMPS) in transmit than the power supply can produce. This
causes the voltage to take a nose dive and causes the radio to go into a reset like your just powering
the radio on.
Jim
Hello All
emtbls1987
MIc Problem
hello all,
Sorry for not really paying attention. i should have realized that like you are saying since the Radio is 100 W it takes more then 13.4 Volts. I am going to measure the Voltage when transmiting and see. i am sure it probably will be not enough im going to see if i can hook it up too two diffrent amps and see if that will help. Also How will this radio work with it just being hooked up in my truck.
Thank You all for the Help, and for being patient with me
emtbls1987
FFPM571
Nashvillle
2 amps arent going to do it. You may need a high output supply or a Car battery and a trickle charger to keep the voltage up when not transmitting. In a truck it will be fine because it will use the battery to supply the amps necessary
ramal121
Lots and lots of watts
Calif Whine Country
the radio on.
Jim
If you are going to check this with a meter, realize that that the voltage drop only lasts a fraction of a second before the radio craps out and reinitializes. A digital meter may not even respond that quick and an analog meter will only twitch a little...
