Guess this is as good a place as any to post my experience with this adapter
[Details]
Status: It's all working.
Adapter: Micro Connectors, Inc USB Serial Adapter (purchased from Frys). E07-160
OS: Win7 x64
Scanner: BCD396XT
Scanner Software: FreeSCAN 2.10
Needed to install the driver that came with the adapter. Disc is labled "E07-161 USB Serial Adapter". There's no Autorun so you need to explore the CD with Explorer.
On the disc is a "All-Windows-WHQL-Driver" directory, and in there is "PL2303_Prolific_DriverInstaller_v1210.exe", which appears to be the same as the latest available from www.microconnectors.com.
Running the installer was quick and plugging in the Adapter (Scanner not connected), Windows found it and added it as a new port "Prolific USB-to-Serial Comm Port(COM3)" as viewed in Device Manager. No reboot necessary.
I made sure the scanner was set to 115200 BPS and then set the COM3 Speed to match 115200 (by default, it was 9600).
After installing FreeSCAN and with the scanner connected, I clicked the "Download from Scanner" button, and made sure the port and speed matched (COM3/115200).
First attempt, I got an error when I clicked "Start Download". So I went back, made sure all COM settings were good. Second attempt also failed. I closed FreeSCAN, re-opened, this time used the "Autodetection" feature in the "COM Port Settings" dialog which found the scanner, and next attempt at succeeded. Possibly some pilot error here.
Upload/Download works as well as using the "Control Scanner" and logging.
[Bottom Line]
Other than the minor issue with FreeSCAN (maybe my fault), adapter works great. I know there's cheaper out there, but this is what I got and this was my experience
[Details]
OS: Win7 x64
Scanner: BCD396XT
[Bottom Line]
