BOBRR
Hello,
Have a new SDS200.
For the front panel micro USB F Port:
Would make a much better setup for me if I can find a right angle connector, or a cable with a right angle connector on it, which has the
Micro USB configuration on each end. Should be, or course, a M and a F.
Can go crazy looking at all that Amazon has, but don't appear suitable. I'm assuming Mini USB is different than Micro USB; correct ?
Do you think this would work :
Thanks,
Bob
SIENOC 2 Packs of Micro USB Male 90 Degree USB Male to Micro Female Plug Adapters
by SIENOC
4.0 out of 5 stars 3 customer reviews
Have a new SDS200.
Thanks,
Bob
by SIENOC
- Type :5 Pin Micro Male to Female Adapter
- 90 degrees conversion plug direction
- Phone charging angle conversion Transfer Data with Computer
- Easy to Use, Plug and Play
- Compatible with: Most Devices with Micro USB
