Microphone modification
IZ2OAV
Como, ITALY
Hi all, I have an original Motorola NMN6193C microphone and I would like to use it on a MOTOROLA DP4800. So, is it possible to change the connector to a M7 serie?
Thank you.
All the best.
K2NEC
NA
Not judging just curious, why do you want to use a jedi mic?
IZ2OAV
Como, ITALY
Ahahah Hi! Vy nice question. Well, I like that Mike and I'm an Ham Radio (WB5ALF) so I like to use solder and screwdrivers...and so...it's a challenge! I have the DP4800 original external microphone. 73.
All the best.
Good DX.
K2NEC
NA
Maybe someone can confirm this but I imagine you can match the colors of the wires on the 2 mics and it should work. You can probably find an XPR connector for pretty cheap and Jedi mics aren't extremely expensive these days anyway so it might be worth playing around with.
