Microsoft Excel, How to limit the number of spaces in a colum
Grog
Banned
West of Charlotte NC
How to limit the number of spaces in Microsoft Excel?
I'm sure there are some excel experts here.
I'm finding that's it a lot easier to setup large trunking systems in excel, then to win97. I finally figured out how to add decimal places after numbers, so that cleared up by TG ID problem. Now i need to know how to limit a colum to 16 spots for my alphatags.
Thanks.
mam1081
Next to a scanner...
I usually make mine turn bold red if it's more than a certain number of characters.
Here's how I do it:
Select the first cell of your "text" range (usually the 1st entry).
Goto "Format" -> "Conditional Formatting"
Change the drop down from "Cell Value is" to "Formula is".
Enter "=LEN(D4)>16" in the box (assuming D4 is your first cell).
Click the format button to change how you want the "errored" cells to display.
Click ok and try it out!
If it works, just click and drag from the lower right corner of that cell all the way to the end of your column of text inputs (it will copy the text that you have in that cell also).
Grog
Banned
Here's how I do it:
Thanks, I was really hoping for a step by step explainatuion. i kinda figured it would not be so hard, just one of those "Duh" moments.
I'll try it out Friday night when I get back to work, and i have time to play on my laptop.
