Microwave Band Choice Backhaul TRS
r60
Location 1
Can you help me understand some of the reasons 11GHZ might be chosen for backhauls of a P25 TRS.
The reading I have done so far leads me to conclude that 11GHZ and up can suffer from rain fade. That is exactly what I am seeing, especially with thunderstorm cell penetration along the path.
Why choose 11 over some of the lower bands? TIA!
GTR8000
NY/NJ Database Guy
BEE00
Sorry, didn't really answer your whole question. Basically you would choose 11 GHz if you needed higher capacity than 6 GHz could offer. One real-world example might be the link between a primary core and a geo-redundant core, where the sites are just a few miles apart, and so the effects of rain fade would be negligible.
What system are you "seeing" this on? Are you looking at the actual microwave levels, or some other way of observing?
prcguy
The engineer designing the system should have calculated everything out including your rain region to provide a certain percentage of reliability like 99.97%. I would want to look at the design records then make a few measurements to see if your getting the expected receive level during clear sky, etc. If not the antennas may not be aligned, chipping away at your headroom and I would also see if someone has added more carriers than the original design called for, that would potentially reduce power in all other carriers. Finally, take a look at the license to see what power level or ERP is allowed and see if there is any system headroom. Sometimes you can bump the power up some to get over some rain fade.
I'm more of a satellite engineer but the same stuff applies for terrestrial and more like tropo ducting and phase cancellation over distance.
r60
Location 1
Sub here. The system is Somerset County TRS. Very little if any information flows downhill. Trying to understand so as to be better prepared.
The license, path and equipment can be seen here. The path from Johnston Drive to Miller Lane is the one of interest.
https://wireless2.fcc.gov/UlsEntry/...tachmentKey=19063885&attachmentInd=applAttach
Suspected path fade is seen a few times a year only with very intense rain and even heavy snow. The path is 11.466 miles and does traverse significant terrain.
These suspect MW events coupled with TV 19 Tropo on Site (3) are making comm’s less than ideal.
No measuring equipment. Only thing that happens is the CC disappears during severe weather a few times a year.
Site Trunking mode does not operate either.
I am getting a better understanding, thanks to all for comments on this thread.
WQPN327
kf8yk
In a simulcast system isolated subsites typically do not enter site trunking. Having one subsite in site trunking and the remainder in wide trunking is a recipe for widespread interference. Site trunking should only activate when the prime subsite loses connectivity to the zone controller(s) and all the subsites enter site trunking together. Standard behavior is isolated subsites simply stop transmitting.
In addition to the previous comments other reasons for picking 11 GHz over 6 GHz: In your market the microwave bands are very congested, getting 6 GHz hops coordinated is more difficult. Another consideration is structural loading of larger 6 GHz dishes due to both the lower frequency and the need for sharper beam patterns for interference control in a crowded band.
NVAGVUP
Per comments above. Many reasons to use 11 GHZ vs 6 GHZ. Another reason not mentioned (Looking at your license), is if 6 GHZ were used/available, your system spare cards/modules would be increased. (Causing higher project costs). I suspect 11.44 m is at the threshold of 5 9 reliability. (The path needs to be run in a link planner to verify). Additionally, Exalt eq is no longer mfg. So even if 6 GHZ were available to license, the path would need a different mfg of eq.
Sometimes dish size comes into play. 6 GHZ requires a 6' dish minimum. (In almost all cases). 11 GHZ (per FCC and path planning) will permit dishes less than 6'. Maybe the towers will not pass structural analysis w/6' dish? (Per above)
Maybe the path frenel zone will not pass w/6 GHZ and pass w/11 GHZ?
In your climate and a 11.44 m hop, several events of rain/snow fade in a year does not surprise me.
Cameron314
That path is 7 miles with 4 foot dishes on each side. Expected RSSI is -32.6 which is pretty hot. I would guess it isn't that or you likely won't see drops. Maybe out of alignment a bit.
  • Like
Reactions: r60
NVAGVUP
Edit- Kilometers vs Miles. (I need a refresh on metric system!) But same principals still apply.
  • Like
Reactions: r60
12dbsinad
Pay close attention to the installation of the dish. There can't be room for error here, many times I've seen dishes move way to much because the structure is not rigid enough, or the tower guys just simply don't align it, or it's missing the return brace (see that often). Just be aware...
  • Like
Reactions: r60
