09-0017 departed ADW just N of Atlantic Cty.
NOBLE asked HUNTRESS to do a FIDELITY CHECK on the radar feed."NOBLE to WIZARD, just want to confirm, are you actually contributing to the surveillance picture out here or are you just here as a contingency?" "affirm we're doing track by exception with the sector." "ok - I think I know what that means, thanks."
HUNTRESS advised NOBLE that Morristown is active. Presuming that means VIP aircraft is inbound and expect increased activity.09-0017 departed ADW just N of Atlantic Cty.
Correct - what TECH reported is the inbound aircraft from the golf course to the airport to get onboard the VIP jet ( which lead to the Mossristown radio call from HUNTRESS to NOBLE.)09-0017 maybe b/u aircraft; making a loop over the Atlantic.
Presume you mean this heloI belive the State popping up and squawking ATC code just before departure and staying on track and not blocked is uncool. Above my pay grade though. Maybe a watcher is watching.
globe.adsbexchange.com
1700 EDT Heading back to Andrews and descending but I do not see AF1 airborne yet09-0017 maybe b/u aircraft; making a loop over the Atlantic.
NJSP helo N6NJ followed the motorcade to Morristown and is circling there, so shouldn't be too long for dep.1700 EDT Heading back to Andrews and descending but I do not see AF1 airborne yet
Interesting, thanks! What I am trying to say is the transponder should probably not be visible. A number of way‘s this could be fixed of course.Presume you mean this helo
ADS-B Exchange - track aircraft live
ADS-B Exchange - track aircraft live - aircraft flight historyglobe.adsbexchange.com
That would be the helo with the USSS agent on board doing area surveillance. Callsign is usually HUNTSMAN (if my memory serves me correct)
Not unusual for them to be visible since they are basically only a tool being used to secure the area local to the airport of threats....the agent used USSS frequencies to alert to any threat.
NOBLE-21 on ZDC 307.275 3 miles non standard front to back req 10 degrees left.. dodging wx I asume.Hearing NOBLE21 on 363.100, just refueled (looks like 58-0071 just popped up on ADS) and ready to RTB "going to be a non-standard formation 2 miles front to back" - and now hearing afterburners over my QTH... "direct Robbinsville maintain FL20... direct Langley via Robbinsville"
CYA!
Okay do not confuse commercial (aka police helicopter) with military aircraft. The mission the helo performs it for surveillance for threats around and on the airfield. Think of it like a police car doing radar work but instead of hiding behind some trees or a hill they sit openly visible - they want the threat to know they are looking for them. Hopefully that will discourage a threat from being in the area of surveillance so task accomplished - if they insist on hiding they will be seen by the helo.Interesting, thanks! What I am trying to say is the transponder should probably not be visible. A number of way‘s this could be fixed of course.
presume 315 might have been NORAD@1715L MARS/DARKSTAR & WIZARD ALPHA, 13927KHz USB for p/p tfc. MARS OP had them move to 13985KHz USB.
2 p/p's; one to area code 609 & 315; both to ATC stations; said they were near Philly area. Aircraft comms were very weak, hard to understand.
609 was SE NJ; 315 was Central NY. Patches ended around 1735L.
