Mid-Atlantic Digital Radio network - Connect Plus system 141
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
u2brent
KRWDPAXKRS1
New License: WRDM315
452.700
461.925
This license may or may not be associated with MADRN. Like all other licenses on this system, they are licensed to Triangle Comm, Centre Comm, etc. And it's conceivable that Triangle may have licensed this for a client and that it may be a separate trunked site. Or, it could be a new MADRN site.
With all of that said, geographically this would be a perfect fill-in site between the sites in DE and the Lancaster / Delaware Co PA sites.
mike
Site 141-62 Chesapeake City MD (Cecil) WRDM315 (Online 08-06-2019)
Neighbor List: LCN & NL not confirmed
  • LCN = X TX = 452.70000 RX = 457.70000 DCC = 10
  • LCN = 6 TX = 454.25620 RX = 459.25620 DCC = 10 CC
  • LCN = X TX = 461.92500 RX = 466.92500 DCC = 10
mtindor
OH/WV DB Admin
Brent,
Are you saying that you've confirmed this online? i didn't see a submission and even though it lists the color code / CC info in the repeater map, I don't know if you are saying that you actually picked it up. But I do see (Online 08-06-2019).
it is online?
Mike
u2brent
KRWDPAXKRS1
Brent,
it is online?
Mike
Mr Tindor,
I did not submit because I need to confirm the LCN.
Just went for a ride today and the 2 known frequencies were getting voice traffic. Sounded like they were just testing out the new site. They both came up as Site 62 CC10 using TG 800 (Maybe Rover is kaput and a tech was using that radio or the site is for them primarily) So I went looking for a CC. I found it but was considerably weaker than the other 2.
Added the CC to those other 2 which were already programed into my MADRN FL and ran LCN finder, I must have caught the tail end of the testing cause I only got 1 LCN with the finder and it's the questionable 6. :geek:
IMHO it needs more work before it's submission ready. Unless somebody has a newer OTA map... :unsure:
So what I got was added to the wiki...
u2brent
mtindor
OH/WV DB Admin
Mr Tindor,
Needs more work before it's submission ready. Unless somebody has a newer OTA map... :unsure:
u2brent
Awesome. Thanks. I've added the site.
Mike
u2brent
KRWDPAXKRS1
Mike
To be clear, I found this online, It was not in the last OTA repeater map that was posted, So I guess you have a newer one that does? (Shows LCN's) IDK :unsure:
I'm not convinced that LCN 6 is correct.. Unless somebody has additional info.. Will need to take the dongles along next time.. Wasn't looking for the site.. Just came upon it by accident/luck..
mtindor
OH/WV DB Admin
No sir. I have not seen a new repeater maps in ages . Somebody might have one, but if they do they haven't shared it with the collective. If I had a new one, the first place it would be emailed would be to you.
mike
u2brent
KRWDPAXKRS1
mike
Gotcha! ;) I'll check again in a few days.. With the proper tools in tow..
mtindor
OH/WV DB Admin
Ok, in that case I'll just add all of the freqs (since you copied traffic on them all) with an LCN of 0 -- and hopefully anyone who cares about listening to the site understands that the LCNs are not confirmed.
Mike
u2brent
KRWDPAXKRS1
Mike
Mike,
Right On!
Brent (y)
u2brent
KRWDPAXKRS1
This is now confirmed! (y)
Site 141-62 Chesapeake City MD (Cecil) WRDM315 (Online 08/06/2019)
Neighbor List: 6 11 14 54 (08/09/2019)
  • LCN = 1 TX = 454.25625 RX = 459.25625 DCC = 10 CC
  • LCN = 2 TX = 461.92500 RX = 466.92500 DCC = 10
  • LCN = 3 TX = 452.70000 RX = 457.70000 DCC = 10
None of those neighbors reciprocate the favor except 54
u2brent
KRWDPAXKRS1
2019/08/09 15:14:53 Freq=454.256250 Current network: 141 Mid Atlantic Digital
2019/08/09 15:36:42 Freq=502.887500 Current site: 141-5 Honey Brook PA
2019/08/09 15:36:43 Freq=502.887500 DCC=5 141-5 neighbor: Site 141-3 Malvern PA
2019/08/09 15:36:43 Freq=502.887500 DCC=5 141-5 neighbor: Site 141-6 New Holland PA
2019/08/09 15:36:43 Freq=502.887500 DCC=5 141-5 neighbor: Site 141-11 Rawlinsville PA
2019/08/09 15:36:43 Freq=502.887500 DCC=5 141-5 neighbor: Site 141-14 Concordville PA
2019/08/09 15:36:43 Freq=502.887500 DCC=5 141-5 neighbor: Site 141-22 Lancaster PA
2019/08/09 15:35:02 Freq=502.962500 Current site: 141-6 New Holland PA
2019/08/09 15:35:02 Freq=502.962500 DCC=6 141-6 neighbor: Site 141-2 Penn Twp PA
2019/08/09 15:35:03 Freq=502.962500 DCC=6 141-6 neighbor: Site 141-3 Malvern PA
2019/08/09 15:35:03 Freq=502.962500 DCC=6 141-6 neighbor: Site 141-5 Honey Brook PA
2019/08/09 15:35:03 Freq=502.962500 DCC=6 141-6 neighbor: Site 141-15 Reading PA
2019/08/09 15:35:03 Freq=502.962500 DCC=6 141-6 neighbor: Site 141-22 Lancaster PA
2019/08/09 15:33:49 Freq=454.275000 Current site: 141-11 Rawlinsville PA
2019/08/09 15:33:49 Freq=454.275000 DCC=11 141-11 neighbor: Site 141-4 York PA
2019/08/09 15:33:49 Freq=454.275000 DCC=11 141-11 neighbor: Site 141-5 Honey Brook PA
2019/08/09 15:33:49 Freq=454.275000 DCC=11 141-11 neighbor: Site 141-6 New Holland PA
2019/08/09 15:33:49 Freq=454.275000 DCC=11 141-11 neighbor: Site 141-17 Red Lion PA
2019/08/09 15:33:49 Freq=454.275000 DCC=11 141-11 neighbor: Site 141-22 Lancaster PA
2019/08/09 15:37:53 Freq=502.912500 Current site: 141-14 Concordville PA
2019/08/09 15:37:54 Freq=502.912500 DCC=14 141-14 neighbor: Site 141-3 Malvern PA
2019/08/09 15:37:54 Freq=502.912500 DCC=14 141-14 neighbor: Site 141-5 Honey Brook PA
2019/08/09 15:37:54 Freq=502.912500 DCC=14 141-14 neighbor: Site 141-6 New Holland PA
2019/08/09 15:37:54 Freq=502.912500 DCC=14 141-14 neighbor: Site 141-18 Philadelphia PA
2019/08/09 15:37:54 Freq=502.912500 DCC=14 141-14 neighbor: Site 141-49 Egg Harbor City NJ
2019/08/09 15:59:57 Freq=454.243750 Current site: 141-54 Church Hill MD
2019/08/09 15:59:58 Freq=454.243750 DCC=3 141-54 neighbor: Site 141-52 Dagsboro DE
2019/08/09 15:59:58 Freq=454.243750 DCC=3 141-54 neighbor: Site 141-53 Salisbury MD
2019/08/09 15:59:58 Freq=454.243750 DCC=3 141-54 neighbor: Site 141-58 Harrington DE
2019/08/09 15:59:58 Freq=454.243750 DCC=3 141-54 neighbor: Site 141-62 Chesapeake City MD
2019/08/09 18:36:52 Freq=454.256250 Current site: 141-62 Chesapeake City MD
2019/08/09 18:36:52 Freq=454.256250 DCC=10 141-62 neighbor: Site 141-6 New Holland PA
2019/08/09 18:36:52 Freq=454.256250 DCC=10 141-62 neighbor: Site 141-11 Rawlinsville PA
2019/08/09 18:36:52 Freq=454.256250 DCC=10 141-62 neighbor: Site 141-14 Concordville PA
2019/08/09 18:36:52 Freq=454.256250 DCC=10 141-62 neighbor: Site 141-54 Church Hill MD
:geek:
u2brent
KRWDPAXKRS1
2019/08/13 21:31:46 Freq=502.862500 Current network: 141 Mid Atlantic Digital
2019/08/13 21:31:46 Freq=502.862500 Current site: 141-3 Malvern PA
2019/08/13 21:31:46 Freq=502.862500 DCC=3 141-3 neighbor: Site 141-5 Honey Brook PA
2019/08/13 21:31:46 Freq=502.862500 DCC=3 141-3 neighbor: Site 141-14 Concordville PA
2019/08/13 21:31:46 Freq=502.862500 DCC=3 141-3 neighbor: Site 141-16 Allentown PA
2019/08/13 21:31:46 Freq=502.862500 DCC=3 141-3 neighbor: Site 141-18 Philadelphia PA
2019/08/13 21:31:46 Freq=502.862500 DCC=3 141-3 neighbor: Site 141-45 Boyertown PA
BM82557
Berkeley Co WV
mike
I have been monitoring other systems lately and the last repeater map I received was in December 2018 ( the same one that is in the wiki). Some of my research has reached a dead end so I will shift gears for a while and park part of my equipment on this system. Maybe I'll get lucky and copy a new repeater map.
mtindor
OH/WV DB Admin
Fingers crossed. I've been too busy with other things as well, as I suspect most of us are in the summer. I'm not really in "monitoring mode" until the leaves start falling.
Mike
