CapMax will beacon like Cap+ if the control channel is shared instead of dedicated.All I can say is that there’s a thread in the Indiana form about ERS – OCI. They have a wide area to connect plus system which is being replaced by a capacity max T3 system and over there. They’ve experienced some of the same things, and somebody in that thread had mentioned, suggesting that they knew what they were talking about, that a particular site could operate in a mode that supports both T3 and Cap+. I don’t know if that’s only a transitional thing or if that’s something that could be maintained for the lifetime. I don’t know if any of it’s true. But it has been reported before.
Roxana, Salisbury and Harrington were decom'd last year. just an observation.L8-4 Birdsboro
Thanks for the great info. That has puzzled me for a while.CapMax will beacon like Cap+ if the control channel is shared instead of dedicated.
Ive been replacing the combiners at each site so far as well. De-tuned Telewaves being replaced with new, shiny, factory tuned TX/RX.It pulses about once every second. 60 BPM..
It's signal is off the scale compared to the constant CC mode previously observed from the same tower.
Apparently DSD÷ is happy decoding this mode.
It must be a real thing.. LOL
I commented about a Cap+ type beacon on a CapMax system a while ago and got good information from several forum users.Thanks for the great info. That has puzzled me for a while.
Mike
454.15625 should come to LSN 6085/6086 LCN 3042New one: Butler knob (Huntingdon county)
On the Con+ side, CC for 141-35 has moved from 454.15625 to 454.01875.
454.15625 is now L8-41, NL 42, 38, 43, 40, 44.
LCNs of 227 (452.825 Williamsport) for 38, and 327 for 43 (454.075 in Boalsburg).
I'm getting all that using SDRTrunk, which is a pain but it is what I can get to work correctly on Linux. Basically I'm going through a chunk of DMR messages manually then writing everything to paper and posting it.Instead of transposing everything it’s probably a good idea to actually try to post a screenshot of DSD plus when you can
Definitely Butler knob, NL matches the one for 141-35 in the wiki. No way I could hear Ebensburg from here anyway.Are you positive that is Butler knob? Neither Butler Knob or Ebensburg were ever published as being online. Both would have had 454.15625 assigned to them.
Butler Knob is a Centre site, CapMax site 41, Conn+ 35.I guess my own problem with "Butler Knob" is that there has never been a PADRN / MADRN map showing the existence of a site at Butler Knob. In the wiki, there is the repeater map (which does NOT provide site names) - Others have went through and labeled each site. For whomever labeled "Butler Knob", I'd like to know how they knew that. Apparently somebody went mobile, with DSDPlus and a scanner without an antenna, and when they noted that they could pull in that control channel without an antenna on the scanner, they deemed that location as "Butler Knob". No geodata information. No information on whether they actually were at / saw a tower that might have the equipment on it.
So no matter if the site is up and operational, who knows where that site really is other than the person who made the notes on the repeater map. Probably a reason why that site had never been submitted to the DB -- they would have been asked some more concrete questions about geolocation data, what they saw when they were there, etc.
And of course that semi-static document of the repeater map from back when it was fetched is being updated with information about L8. Good grief. Nothing likely mangling historical data so that it all becomes nonsensical and useless.
Mike
Thanks for the confirmation!Butler Knob is a Centre site, CapMax site 41, Conn+ 35.
The corresponding sites in the OneVoice MAX sites wiki have been marked as red. (I want to leave them in the wiki for now, just to keep track). DB has been updated, too, I see for both systems.
I also was bored and made 2 additional Wiki pages for the MADRN T3 system: (I see that @mtindor created the system wiki page, thanks!)
Mid-Atlantic Digital Radio Network (Tier 3) Unconfirmed Talkgroups - The RadioReference Wiki
wiki.radioreference.com
Mid-Atlantic Digital Radio Network (Tier 3) Unit IDs - The RadioReference Wiki
