Mid-Atlantic MilAir 2023
Earlier this evening AZ ANG K35R TEDDY 11 departed KBGR to AR with 3 B-1s, callsign sounded like THICK (?) 11-12-13. All 3 B-1s ended up turning around and RTB to Ellsworth.
LiveATC Gander Center
There is another AZ ANG K35R TEDDY 12 also staged in KBGR. So maybe another B-1 mission coming up, or they try this one again ?
Nice catch! Thought that AR-20NE Res I posted was odd.Seems was a Reykjavik and later rtb mission.
AR-20SW Res 1800z-2100z up now showing same altitudes FL-150-FL280.Not sure if this was for the
original mission and they left it up or somebody else coming back West this afternoon.
Hbright
VA ArNG helos. I think that ROGUE are H60's, possibly 2/224th Avn. Pretty sure that LEGEND is medevac...maybe H72's.
73/Alllen (N4JRI)
Thanks.
Check out this STARS TG (this recording unfortunately only scans the NoVa sites). Seems like a state-wide channel for tracking of DMA/VANG aviation resources. Appears that the RRDB label is inaccurate, if anyone has info on the correct AlphaTag/name for this channel, that’d be much appreciated.
hrspotter
Jet noise lover
Southeast VA
A few days ago:
No more C-2s on the West Coast. At the bottom of the article it notes that the Greyhound will be used a few more years on the East Coast. However, I talked to the pilots at the VAW-120 tent at the Oceana Airshow, and they did say that the preparations for the CMV-22B are almost complete, though it doesn’t seem like the apron heat treat or taxiway expansion outlined in the proposed action has been started yet.
ADS-B Exchange - track aircraft live
frank3si
New Castle DE
A few days ago:
Sad to see this. I was thrilled to have a chance to photograph a Greyhound along with a few Hawkeyes when I was at NASA Wallops Flight Facility earlier this year. They were doing repeated touch-and-gos for hours...
NASA used a C-17 to fly that comet sample from Utah to Ellington Field Texas this morning.
RCH-347 #99-0166. They put probe in Nitrogen flow container for decontaminant purposes.
Signature Flight Service for C-17 refuel.. Lot of Pax and luggage :)
hrspotter
Jet noise lover
Southeast VA
Tried out my scanner again today - listening to FCLP. Squelch was all the way down at 2 and I was close enough to see the pilots' helmets, but all the transmissions sounded clipped. "Roger, ball -- manual", "--'re on glideslope", etc. Still using the rubber duck and the scanner was upright on the ground and not moving. Is that just a product of the helmet mics or is there an issue with my equipment? Any help would be appreciated.
I did get a picture of a Hornet with all its drop tanks, despite my camera refusing to focus in such low light.
DAILY GUIDANCE FOR TUESDAY, SEPTEMBER 26, 2023
9:55 AM THE PRESIDENT departs the White House en route to Joint Base Andrews
10:15 AM THE PRESIDENT departs Joint Base Andrews en route to Wayne County, Michigan
11:35 AM THE PRESIDENT arrives in Wayne County, Michigan Detroit Metropolitan Wayne County Airport, Romulus, Michigan
2:35 PM THE PRESIDENT departs Wayne County, Michigan en route to San Francisco, California
PDT
3:55 PM THE PRESIDENT arrives in Santa Clara County, California Moffett Federal Field, Mountain View, California
7:35 PM THE PRESIDENT departs Santa Clara County, California en route to San Francisco, California SLAC Landing Zone, Santa Clara County, California
7:55 PM THE PRESIDENT arrives in San Francisco, California Crissy Airfield, San Francisco, California
DAILY GUIDANCE FOR THE VICE PRESIDENT FOR TUESDAY, SEPTEMBER 26, 2023
At 10:05 am ET, the Vice President will depart from Washington, DC en route to Atlanta, GA.
At 11:45 am ET, the Vice President will arrive at Hartsfield-Jackson Atlanta International Airport.
At 4:55 pm ET, the Vice President will depart from Atlanta, GA en route to Washington, DC. This departure will be from Hartsfield-Jackson Atlanta International Airport.
On Thursday, September 28, Vice President Kamala Harris will travel to Miami, FL
jsoergel
Cincinnati/Dayton, OH
Clipped transmissions at the beginning of a transmission are usually going to be a function of either the scan or the squelch not opening quickly enough. For the former, you can park it on the primary FCLP frequency. For both, there should be settings you can adjust to help the sensitivity (depending on your scanner model).
I will say that a rubber duck antenna will never perform as well as a mobile or base antenna. That is likely the main source of losing bits and pieces of the conversation.
Hbright
1313E: Foreigners landing at ADW? Two thick accents now on 118.4. C/s is [Unintelligible] 0601.
1316E: Now two TIS-Bs. The other c/s is [Unintelligible] 0603.
Update: apparently It's the Italians. ADSB briefly showed a IAM0602, so I assume it's a flight of three (at least).
The 3x Tornados came back east yesterday, stopping in Pease for fuel.
