Mid-Atlantic MilAir 2024
mdmonitor
0950- Unid ftr ????-91 off ADW (257.2). Can't make out callsign. Switches to Potomac (254.25) then ZDC Hagerstown (227.125)
1015- Unid acft check in w/Giantkiller (135.725). Advises they will work in W107 w/Devil & Wild flts. Maybe Folk 53 (KC-46 # 21-46061) showing on ADS-B in the W107 area.
mdmonitor
1015- Phoenix Air Group Lear 35 (N80PG) land at ADW (118.4)
1030- Wild 11 flt (DC ANG F-16s) off ADW (348.725)>Potomac (317.425)>ZDC Baltimore (360.7). A2A is 238.175.
1040- Derby 03 (C-130J # 17-5865 165th AS, KY ANG Louisville KY) working MD ANG Raven Ops (275.7) w/inbound msg. Advises they will do engine running offload (ERO).
paradiver
Middle River, MD
Hobey51 flight in ZBW Sector 1 Millinocket dragging something north in Block FL25-26 Bison31 reported problem and making right turn. On a tape at 1527Z
Actually they reported block FL240-260 and will be turning around at USA/CA border [1535z]
mdmonitor
1154- Couple of CG MH-65Ds working intercept practice w/Huntress (139.7). Make ref to " push to CG 106" which is 141.55. Also working on 345.0
1203- Decoy 99 (C-17 # 94-0070) off Martinsburg. Working Mountaineer Ops (297.9) asking about tanker status and AAR timing. Prob heading up to AR 218,
frank3si
New Castle DE
Mark, here's the one you mentioned. A pair of C-130s from the 166th Airlift Wing at KILG were doing touch and gos this afternoon, when they were joined for a few passes by MC-130J Commando II 5973 from Air Force Special Operations Command. Bad light for photos this afternoon, but definitely a 130 model upgrade. This was from my upper deck.
mdmonitor
1520 Score 48 (prob MQ-4) out in Test Track at FL500. working Giantkiller (238.1) for "Chesapeake transition" to PAX at FL500. NOTE: I've not heard the term Chesapeake transition used before. Seems it's when acft offshore come ashore at the mouth of the Chesapeake Bay, near Norfolk then head up the Bay to PAX.
