Middlebury Police
izzyj4
Ova here
The FCC had an pending application / modification received on 10/27/11 for a new VHF radio system for the PD, callsign WQBP299.
http://wireless2.fcc.gov/UlsApp/UlsSearch/license.jsp?licKey=2671251
AND
ULS Application - Public Safety Pool, Conventional - 0004930349 - MIDDLEBURY, TOWN OF
The frequencies listed are;
154.7775 - Mobile and FB2
151.1225 - FB2 and FB2S
159.2175 - Mobile and FB2
158.9025 - Mobile
I know they had coverage issues with the old low-band radios for years and were trying to update their radios. Have to keep an ear out for when they are testing or if this is actually old news.
Firebuff66
CT
ULS License - Public Safety Pool, Conventional License - WQBP299 - MIDDLEBURY, TOWN OF
AND
158.9025 - Mobile
Joe
Middlebury PD is up on a VHF digital encrypted system, about 8 months now. Fire went on VHF about 2 years ago, system sounds good from the valley :)
cg
Connecticut
When you look at the FCC Application page, look under "Trans Log". That will show what changes have been submitted to the FCC.
It looks like they have changed from Utility Comm to NE Comm, are adding
a site on Breakneck Rd using 159.2175, and changing from the FD to PD for mail sent by the FCC.
chris
izzyj4
Ova here
Thanks guys, I'm a little behind the times re-programming my scanners! :)
55engine
Hartford County area
middlebury police
I look at the fcc datbast and found the feq and no 159.3175 is not comeing up for middlebury police
159.2175 in comeing up for pd so and 159.3175 will not working my scanner?
izzyj4
Ova here
Ummm....okay. Can you fix your sentence structure so its readable please. I'm not trying not to knock you but I do not understand what your are trying to get at.
But what I can gather is that you are trying to program in 159.2175 into your scanner and its not going in? More than likely your scanner is an older model and does not accept the new VHF narrow band splits. It will just round up to the next frequency under the old splits. Also you will not hear MPD anyway as the guys previously said in the thread the transmissions are encrypted (scrambled), you'll just get noise.
cg
Connecticut
159.3175 (I don't know why that freq came up) is not a 7.5KHz channel so it should not be able to be entered when set at 7.5KHz steps.
159.2175 is a legit channel so the scanner will take it. If a previous channel or the default is set for 15KHz, 159.2175 will not go in. Go to STEP and change it to 7.5KHz and then re-enter the frequency.
chris
CT22
CT
Check the instruction manual that came with the scanner. There is step by step directions.
