Middletown P25 phase II
nick91
Attempting to listen to Middletown with a BCD996P2. From Burlington i pick up Wallingford and Meriden pretty clear. Copied Middletown's feed from radiorefernce on free scan but says its still searching for control channels after i put in the APCO band....any suggestions?
nick91
I am in Middletown .
PD is encrypted so all you'll hear is Public Works and Fire.
If you can't receive the control channel , you won't hear anything.
The active control channel is 859.5125
Ah, thank you I'm only trying to listen to fire talkgroups but i might just be too far. New Britain did the same thing then all of sudden started coming in clear.
cg
Connecticut
The range doesn't work that accurately but you are still a long way for consistent reception. I receive the control channel from Granby clear enough to run DSDPlus but cannot monitor the voice, not quite enough power to get a decent signal through.
Lots of hills and hollows, depends where you monitor from.
chris
t5holmes
Middletown Ct
You should be able to hear them on clrm as they are hooked into it. I hear them on other than there own system. It’s a 65xxxx talk group.
Reconrider
EST
65xxx is roaming tgids. Anyone can use them if they need to(programmed to be allowed)
55engine
Hartford County area
somebody told me that they submitted it that’s why I was asking about this channel But I will request it as well as that other person this conversation is done
W1KNE
Owner ScanNewEngland
New England
Yes.Then I think that if the VHF channel can no longer be heard I think it should be taken out of the database
If the VHF Repeater is in place as a backup to the trunk, the entry in the DB will remain. If the VHF equipment has been removed, repeater and all other radios, then it will be tagged depreciated and auto purged. I'll double check that the naming field is correct.
