Midland 1001LWX and Radioshack TRC-99C
2000dakota
I have a few questions about my new Midland 1001LWX and the pair of RS TRC-99C's I have. I wanted to see if the two different radios were comparable, so I switched the crystals in the TRC-99C to have x2 27.085Mhz crystals in both transmit and receive, and tested it out. I receive what the walkie is transmitting just fine, but when I try to transmit on the 1001LWX, a few clicks are heard, but nothing else.
Is there something wrong with my Midland?
Can I not transmit to the walkie?
Thanks.
KD8DVR
Columbus, Ohio
You have the wrong receive crystal installed. The receive crystal is the difference of the frequency desired plus or minus...i forget which, of the radio's intermediate frequency (IF).
WA0CBW
Shawnee Kansas (Kansas City)
As KD8DVR said receive crystals are higher or lower by 455Khz (or whatever the IF frequency of your receiver is) than the actual receive channel frequency. A Transmit crystal cannot be used in the receiver as it is the wrong frequency for the receiver and a receive crystal will not work in all receivers because of different IF's and either high or low frequency injection of each receiver.
BB
