MILAIR Feed
BMT
Download Pro Client and listen to Navy Air Ops. Click on Deltona,FL and monitor.
Aug 6-9 Navy will be making live drops at Pinecastle Range.
BMT
KI4VBR
Palm Harbor, FL
More Info Please....
BMT
What do you mean "Pro Client" from where?
KI4VBR
Palm Harbor, FL
Next Step....
Go to the website link below and download Pro Scan - Free Client 5.5 and install then run the program then scroll down to Deltona and click on start.
ProScan
OK, downloaded the free client, installed & it is up & running. I do not see where I can scroll down to Deltona. Does this require me to have it connected to my 396xt or does it pick up a stream online?
Tnx,
V
N1XDS
ÆS Ø
Tnx,
V
V,
It streams online from other people who stream live feeds of whatever they have programmed in their scanners. Open up the Free Client program once it's open and running on the screen click on the option that says Remote Scanner Over IP under the channel read out. Once you do that click on Update middle right side in red letters then it'll show a list of live feeds click on Description it'll make it where the feeds show in alphabetical order scroll down to Deltona double click and you'll see on the left side Client: Server IP address or Name of the feed your wanting to listen to click on Star in red letters.
- Jamie
BMT
Weather had me shut down for over an hour.
MILAIR isn't like police and fire!!
You just have to wait until something pops.
BMT
N1XDS
ÆS Ø
BMT
I appreciate the feed BMT...I haven't heard much lately accept for Pinecastle Range on the feed. :D
nyair1
BMT
Wow i have been using pro-scan to run my radio at home during the day while i'm at work and i never knew about using it like this. I have limited freetime to play around with it. Can i set this up to record what is coming from your feed and play it back later? Or can i only listen to it in real time? How do i go about setting up my scanner to feed it online? I would be able to listen to it at work then during the day. Thanks guys.
