Milair traffic heard today
splash1
Eastern Iowa
07-07-09
Jared I checked my recording and didn’t hear anything from Mutant 01.
13:40hrs (353.550 Kankakee high) Cobra -82> (319.200 KDIZ Rossville)
13:47hrs 321.0 Upset-51 Will be in about 20 minutes, no write-ups.
13:58hrs 319.200 Cobra 82 request over fly of point, then right hand turn the long way around, then back on course.
14:11hrs cobra-82 request direct Lamoni
14:47hrs 372.200 Sounded like Fuzzy calling Volk ops 10 minutes out 4 pallets to off load.
18:51hrs 379.400 ? C-21 Tail no 60377 on ground at 1915 off load Navy code 4 need 2000Ibs of fuel then something about 150 to 300gals of ? Fuel.
21:30hrs 321.0 Upset -61 and Artic-? Upset passing on to ? Ops we are ½ hr out of Milwaukee. Then Artic calling UPSET 61 telling them they are 10 to 15 minutes behind them.
Rick
splash1
Eastern Iowa
07-13-09
15:37 hrs Dixie-33 calling Milwaukee Command Post on 321.0 requesting they call phone # .Also checking weather for KDHN Dothan Regional Airport
Dothan, Alabama.
Rick
kaktis
311.0 Gametime calling Raymond 21 (Offutt) numerous times, no response from Raymond 21
Never heard gametime before, no idea on ID
Brian
splash1
Eastern Iowa
07-23-09 11:45am
Raptor-01 and Bat 81 on (373.100 BATCAVE COMMAND POST) and 376.025 Direct to Andes MOA, Fl at 310 cleared for time in the block. Also caught CHISEL-21 and TOPCAT on 257.925 & 370.950. Volk Moa area busy again the morning.
rick
nodak1crdet3
Detroit, MI
Rock 32
138.450 and 138.350 with Rock-32 and Darkstar this morning. No location heard, but the closest active MOA would be Falls / Volk.
255.400 with Pat-675 heading to Andrews 11:19 am
Rick
ROCK is a common call sign for Madison F-16's.
This is their Victor freqs.
138.250 V01 Badger Ops.
138.350 V15
138.450 V16
139.800 V17
143.800 V18
JLM7424
Williston,ND - Williams county
That's not a easy question, but I'll try. First start by reading the wiki file here; VHF/UHF Military Monitoring - The Radio Reference Wiki
Then read the RR forum under military monitoring here; First Time listeners - The RadioReference.com Forums
Your very close to the Crypt MOA ( Military operations area) It covers a large area of north western Iowa.
Special Use Airspace & Air Traffic Control Assigned Airspace
Frequencies reported to be in use for the Crypt MOA 233.400 and 311.300
You are also close to an air refuel route (AR105) that runs through the MOA
Primary freq 238.900 ,Secondary 320.900 , Entry/Exit 269.000
Should also be able to hear the F-16s from Des Moines.
IOWA* 132nd FIGHTER WING ANG F-16s from Des Moines Airport
138.150 VICTOR -01 ( All AM Mode) (ALSO KNOWN AS HAWK EYE OPS)
138.200 VICTOR -12.
138.300 VICTOR -13.
138.400 VICTOR -14.
139.700 VICTOR -18.
252.900 UNIFORM - 01 (ALSO KNOWN AS HAWK EYE OPS)
307.150 UNIFORM- 05
288.300 UNIFORM - 11
311.300 UNIFORM - 12
233.400 UNIFORM - 13
298.600 UNIFORM - 14
269.625 UNIFORM - 16
363.200 UNIFORM - 17
316.900 UNIFORM - 18
260.400 Hawks nest
Call signs used by the 132nd FW are HAWK EYES; PANTHER; CYCLONE; BULLDOG;
Other reported call signs used by 132nd FW are TACO and VIPER Note: I haven't heard them used around eastern Iowa except by other fighters in the area.
_____________________
More Air Tactical frequencies used by 132nd
138.100
138.500
138.875 also used by 185 ARW
138.900
139.900
321.100
353.900
NORAD 364.200
FSS 255.400
Rick
Hi Guys I,am getting actively interested in Flt-comms just picked up a mvt-7100 and have a
Signal Comms R-535 on the way (Ebay) So I,am Wondering is Crypt a pretty active area i seem to be lucky enough to live right below it in Orange City,Ia?
What Antennas and recievers are you guys Using if i may Ask ?? Anyone In My Area ?
Thanks Matt.
JLM7424
Hello
The Crypt and Howard Moa’s are active as I type this.
My current radio use for milair is
Bc780xlt base
Bc898t base
I also use a pro 43 and a pro 97.
Antennas
Radio shack Model: 20-176 | Catalog #: 20-176 about $27.00 .
A scantenna and a DPD productions miltenna omni uhf/vhf
DPD Productions - Antennas & Accessories for the RF Professional & Radio Hobbyist.
Happy scanning
Hey Thanks Splash1 Do you get Crypt then i take it from your Qth?
Unfortunatley i drive Truck for a living and i,am stiing in Harrisburg,Pa so i cant check out Current Crypt till i get home. i will search here though i have my yup 7100 and 396t with me.
Say 1 more ? being new to this i,am not sure The name Crypt does it get used in some of these Transmissions i mean will it be heard ? Thanks Splash !
splash1
Eastern Iowa
Howard Moa active this am.
257.900 Howard Moa
138.150 A2A
138.300 A2A
138.400 A2A
319.200
307.150
328.400 Ccenter/ cedar rapids low d
callsigns in use Panther ,Cyclones, Bulldog they also mentioned Loudspeaker and Colt team. Doing some ground targets at this time taking out an 18 wheeler and a house. Also targets on a terrorist van.
Lighthouse about 35.to 40 minutes out on 233.700 tacamo koff
Air Refuel route 318 active 240.350
Skull-31 talking with CCenter on 351.700 Quad city
Rick
splash1
Eastern Iowa
JLM7424
I don't usually hear the Crypt moa from my location useless they are flying high or the weather conditions are just right. I can hear the east end of the air refuel route.
While you are in Pennsylvania there are two moa's, one in the north central part of the state and the other on the coast. They also have several training routes.
While traveling i often use the Radio shack mobile antenna Model: 20-032
Catalog #: 20-032
wn0r Brian may be able to answer your Crypt questions
See and Avoid
Eastern Iowa Milcom - The RadioReference Wiki
JLM7424
Hey Splash1 Good Recomendation on the RS Ant i picked one up at a mall on the raod here In ,PA
Bought the RS 20-176 ant 10' of Rg8 and went to lowes got 3 mast poles that are flanged to go into each other Wow what Diiference this ant is making as a portable set up have the bottom pole sitting
on part of my mirror bracket and a bungee holding it their while i sit parked picking up ALOT !!
Wow Heard a bit of Activity on 139.6 A in mid central ,PA
Anyway i will return this to a IA Thread Thanks for the help i will be getting another one of these Ant.
For My House 73's Matt..
splash1
Eastern Iowa
08-08-09
07:54 am local (344.600 Pilot to Metro) JOSA- 118 heading to Iowa City them to Rochester looking for weather between.
11:24 am local (319.700 AR 016) Unknown with air refuel ops.
12:11 pm local (353.550 Kankakee) Buckeye-01 down to 280 direct to (sounded like he was trying to say Keokuk).
14:29 pm local (252.100 305ARW/934AW) Air to air chit chat something about Des Moines to Dubuque then to Minneapolis. No call sign heard.
rick
splash1
Eastern Iowa
Forgot to post 08-07-09 logs.
10:08 am local 257.725 > 327.150 > 257.925 with Unknown.
10:41 am local (239.800 AR 105P) No callsign heard.
11:35 am local (138.300 Air to Air) No callsign heard.
12:56 pm local 252.100 Air to Air chit chat no callsign heard.
12:57 pm local 138.300 >138.400 Unknown (Getting sick of this)
14:15pm local (284.620 Minneapolis) Gitmo-41 checking in at 270 (Hurray finally a callsign heard)
14:53 pm local (323.025 Minn/ Mason city d)(SL) Duke-61 checking in at 270 then to 372.00 Duke 61 push to 327.150 ......> 323.025> 363.000> 323.025.
15:10pm local ( 363.000 FAA to ATC) Duke 51 at 17thousand looking for lower may have to spilt up the 4 aircraft 54 first in 53,52, 51 in about 5 minutes.
15:28 pm local (290.700 KZKC-Quincy) with unknown
15:45pm local 327.150 CC/DBQ high with MADCAT-91 at 330 looking for 240 >281.400 CC/DBQ low d
rick
JLM7424
Sorry Dont have time to Cypher all this audio i live in orange city ,Ia NW / IA
I got a my antenna up a bit higher Roof Tripod 10' Mast pipe So Antway Thanks to Splash1 and some of his help and Knowledge i got my setup Decent for now so i,am picking up a bit better
my Signal Communications R535 will Unfortunatley show up tommarow and i have to hit the road for 6 days of trucking will test it out when i get home supposed to be the benchmark Air reciever
So Finaly heres some Audio From Crypt MOA I Beleive. 138.2 Am At 9:15-9:45 pm CST
This is my Site Feel Free to download it .MATT
http://www.killfrunkus.com/RR/138.200am orange city.ia.mp3
splash1
Eastern Iowa
08-11-09
11:39 am local 269.075 Air traffic control FAST -21 wanting direct Twins then direct Minneapolis. >307.900 at 11:45 checking in.
IowaBrian
Michigan
I am in Iowa near Cedar Rapids and I am using a DB4 TV antenna that is on a broom handle and leaning on my deck rail :) Also have about 100 feet of RG6 so not what I call a good scanner setup or even a great HD TV (which is what I bought it for) setup. I will have to add a amp for the HD it works fine in good weather but sucks in anything else. I will also get it on the roof this weekend if it stays cool I hate getting on a hot roof!
I think I will get an Antennacraft scanner antenna they are about 50.00 so not bad.
