MacombMonitor
- Joined
- May 18, 2005
- Messages
- 3,551
What connection(s) do they actually have?FrankJ said:You might want to try this yagi for Milcom. It's made for 220 Mhz ham band, but it should work well for 225-400 Mhz as well.....It's cheap too!
http://www.centerfireantenna.com/220yagi.html
tonsoffun said:Hey Bill,
Where did you purchase that antenna, Links? or any info would be cool.
Do they make anything for 138mhz to 142mhz.
Ron
MacombMonitor said:This "one" I found new on ebaY for only $23.00! It's manufactured by Bluewave Antenna Company, in Canada (Lucky you). They make them for all different frequencies. The ebaY deal was exceptional, normally they are much more expensive!
Bluewave
http://www.bluewaveantenna.com/
Bill
tonsoffun said:Thats a mint deal!. Do you know what series it is? Its looks like they have 4 series of antennas.
Thanks for the info Bill.
CSL126 said:I know that Yagis are supposed to be pointed in the area that you're wanting to recieve, but what if the aircraft transmitting is not in the direction of the antenna. Will the reception still be adequate?
K8PBX said:Hey Bill... you plan on putting up that AOR SA7000 antenna too?
I'm anxious to hear how that one works.
VernM said:Hate to rain on your parade, but a three element Yagi, with only one director, is about as good in any direction as any vertical. It's directional gain is zip! Well, maybe not zip, but close to it.
n3bxv said:Hey MM,
Did this antenna not work out well for you? Or was the Miltenna LP just better?
