Military Aircraft Or Tower Scanner Codes?
Goldsboro, NC
I have a Uniden Trunk Tracker Iv Watson WSMA-801 Radio/Scanner
Does anybody know anywhere I can find the Seymour Johnson Air Force Base Radio Codes?
Like the Frequency codes to listen to the tower and aircraft talking to each other?
kma371
Are you looking for the frequencies to listen on a scanner? Not sure what you mean by "radio codes"
You can check out airnav.com and search that airport. You will find tower frequencies as well as ground control and approach frequencies.
Sent from my iPhone 4 using Tapatalk
KD4JAF
Brevard County FL
KGSB-Seymour Johnson AFB
As mentioned above, airnav.com is a starting point
Airport Communications
ATIS: 317.625 [1200-0430Z++]
SEYMOUR JOHNSON GROUND: 138.1 275.8 [1200-0430Z++]
SEYMOUR JOHNSON TOWER: 126.25 370.875 [1200-0430Z++]
SEYMOUR JOHNSON APPROACH: 119.7(111-257) 123.7(258-110) 273.6(111-257) 290.9(258-110) [1200-0430Z++]
WASHINGTON ARTCC APPROACH: 127.3 [0430-1200Z++]
SEYMOUR JOHNSON DEPARTURE: 119.7(S) 123.7(N) 273.6 290.9 320.1 N 338.6 S [1200-0430Z++]
CLEARANCE DELIVERY: 128.025 270.8
4FW COMD POST: 311.0 321.0
916 ARW COMD POST: 311.0
ACC SOF: 376.1
CP: 318.3
EMERG: 121.5 243.0
IC: 119.7(111-257) 273.6(111-257)
PMSV: 323.925
PTD: 372.2
RAYMOND 25: 381.3
RDR: 256.8X 326.2
WX AWOS-3 at GWW (7 nm N): 118.975 (919-731-4473)
WX AWOS-3 at ISO (17 nm E): 132.75 (252-522-2712)
TA31 PAR ANTENNA LCTD LAT 35-20-27.28N LONG 077-57-37.65W.
APCH/DEP SVC PRVDD BY WASHINGTON ARTCC (NEW BERN RCAG) ON FREQ 135.5/272.75 WHEN APCH CTL CLSD.
(CALL RAYMOND 25, HAVE QUICK TIMING UNAVBL.)
NO-NOTAM MP 0900-1100Z++ FRI.
stardog01
Brentwood, TN
On the frequencies for ground, tower, approach, etc., what are the numbers in parentheses that follow the frequencies?
Like the (111-257) following this approach freq:
119.7(111-257)
I'm very new to scanners, so this might be obvious if I knew more.
Thanks!
stardog01
Brentwood, TN
Probably heading in degrees for approaching or departing different directions.
Oh yeah, that makes sense. It must be to keep radio traffic separate based on where the aircrafts are in their headings to or from the airport. Learned something new.
I though it was an additional way to define a frequency, but it actually doesn't have anything to do with that.
Thanks!
CalebATC
Blairsville, Georgia
119.7(111-257)
Thanks!
Aircraft on a radial of 111° to 257° radial (of the airport) will use that approach frequency.
You may see other locations where they have four numbers; that's local time.
RMPDCOP
Nashville, NC
Here is a little extra. The number beside the the callsign is the year monitored.
PTD: 134.9, 372.2
Tower: 126.25, 370.875
Approach/Departure: 119.7, 123.7, 273.6, 290.9, 338.6
Metro: 323.925
GCA: 253.6, 326.2
Ground Control: 275.8
4th FW (333 FS, 334 FS, 335 FS, 336 FS) (F-15E)
Callsigns: ADLER (09), ALOFT, ARCHER (09), BARLEY, BLACK, BURNER, BUTLER (09), CAESAR (08), CANDOR (09), CANOE (09), CARSON (09), CHEETAH (09), CHICO (08), CIDER (07), CREEK (09), DIME, FANGO, GOATEE (10), GRUMPY (09), JACKAL (10), KIOWA (09), METEOR (09), MINT (10), OLDS (09), PIKE, RAVAGE, RED DOG, RINGO (09), RUCKUS (09), RUMMY, SABER, SCUD (08), SLEDGE (07), TORCH, TRICKY (08), VEDA (09), WACO (10), WAPPO (09), ZESTY (09)
Command Post (RAYMOND 25): 381.3
4 FW CP: 311.0, 321.0
4 FW SOF: 376.1
4 FW Air-Air: 300.325, 300.625 (10), 300.725 (10), 300.825, 301.025 (10), 354.2, 377.85
333 FS "LANCERS"
Callsign: ARGUS (11), BURGER, CADET, CRAB (08), DUSTY, GATES (11), INCH, LANCER (11), MITT, MOSS (11), SAWS, TEAK (11)
333 FS Air-Air: 300.125 (10), 300.225 (11), 300.525, 300.625, 300.725, 300.925, 301.025 (10), 301.125 (11), 301.325 (11), 301.425 (11), 333.1, 333.4, 333.5
334 FS "EAGLES"
Callsign: EAGLE (10)
334 FS Air-Air: 300.825, 383.3
335 FS "CHIEFS"
WIGWAM OPS: 298.6
Callsigns: ARROW, CHIEF (11), HOAX (09), KONG (10), MOHAWK (11)
335 FS Air-Air: 252.525 (11), 300.125, 300.525 (09), 300.725 (09), 300.925 (09), 301.225, 301.525, 335.1, 335.2, 335.3, 335.4, 335.9, 336.225, 337.85
336 FS "ROCKETEERS"
Callsigns: CARVER, GUNDOG (10), INTERN, MAGNET (10), PLAYER, RAMROD (11), ROCKET (11)
336 FS Air-Air: 252.525, 300.125, 300.925, 301.225, 336.4, 336.9
77 ARS/916 ARW (KC-135R)
Callsigns: BACKE
Command Post (LIGHTHOUSE CONTROL): 311.0
