Military P25 TRS in Columbus
Thunderbolt
Global Database Administrator
Moderator
Ann Arbor, Michigan
I've had a report of P25 TRS that has come online in the Columbus area. Apparently, the data channel is active on 380.575 MHz. Can anyone confirm as to whom this might be?
73's
Ron
dlwtrunked
73's
Ron
Probably the Defense Supply Center Columbus (DSCC) which was on 400 MHz and likely planned to move to a P25 380 MHz system.
au1344
Ohio
I will check later this morning and report back. I live close to DSCC so if its them I should get it no problem.
Thunderbolt
Moderator
Ann Arbor, Michigan
The person who actually heard this system was in the area of I-270 and I-670, north of the Columbus International Airport (CMH).
73's
Ron
gtaman
GALAXY 19 91.0° W
73's
Ron
I know the DSCC uses conventional P25 for security. It maybe them testing a mobile fob system. Also the postal service has a DMR system in the federal range at the P&DC at Citygate
au1344
Ohio
Ok, I have checked this on Pro96Com. 380.57500 is the control, 380.42500 and 380.27500 are listed as alternates. 380.72500 and 380.07500 are data frequencies. System ID is 13A, RFSS 001, Site 002, P25 Phase 1. I am pretty sure this is DSCC given my proximity and strong signal strength, but only more data collection will prove that. So far only the data frequencies are being used. An import from RR shows this as the Defense Logistics Agency Nationwide system. I will submit.
