Military Radio Repair
Pathfinder6
Hi from Tampa, folks.
I have a PRC-113/RT 1319 radio i'd like to get checked out. It doesn't seem to receive aircraft as well as i think it should. My frame of reference is bad though, since i used that same type of radio when i was in the army and the aircraft were generally nearby/overhead.
Anyhow, i'm looking for somebody qualified and experienced with cracking open these old Magnavox/Raytheon radios and performing diagnostics, as required.
Anybody know somebody--preferably in Florida--that could perform those checks?
dee
iMONITOR
Macomb Twp, Michigan
The PRC-113/RT 1319 was intended for short range line-of-sight communications so chances are there's nothing wrong with it. A good antenna mounted high would no doubt help out a lot!
I'd highly recommend this one:
MilTenna Omni UHF/VHF Base Antenna
Pathfinder6
Thanks so much for the help, gents. I've reached out milspec390...will advise. Thanks again to both of you!
dee
Pathfinder6
No answer from Paul yet. Do you have his phone number? I may be ending up in his spam folder.
